05-12-2011, 02:17 AM   #16
creampuff's Avatar
QuoteOriginally posted by Pentaxor Quote
I would say the shell is different from the normal FA lens. it's a bit more durable, IMO.
It is also dead easy for the FA Macro to pick up scratches on the surface. That's why it is very difficult to find an unblemished scratch-free copy. One of the reasons why I switched to the current DFA WR, the other being the noticeable weight savings and invaluable Quick Shift.
05-12-2011, 06:27 AM   #17
bdery's Avatar
QuoteOriginally posted by Donkeypunch Quote
You also need to take into account there are more reviews on the D-FA vs. the FA, so that alone will drive the review average down a bit more on the D-FA.
QuoteOriginally posted by djc737 Quote
I am trying to decide weather to get a FA version for about $400 or a new D FA WR for about $630.
If you're ready to shell that price, go for the newer, WR version. If you find a solid deal on the older FA (I got my FA50 macro for 150$) then consider the older model.
05-12-2011, 07:56 AM   #18
I had the F and the FA at some point. Both performed the same except the FA has a limiter. The D FA (I borough one from my fried) gave me similar results. It is light and easy to handle. The Newest WR is nice and you will have no worries shooting in wet conditions.
Go for the D FA WR one IMHO.
05-12-2011, 08:49 AM - 1 Like   #19
djc737's Avatar
Well after reading all of your well thought out replies, I am going to get the 100 WR. Best match for my K-5 and keeps my belly pack nice and light. Thanks again for all the input, Dave
05-12-2011, 11:37 AM   #20
Roland303's Avatar
Consider that I have the FA 100 currently, if I was starting over again and had to buy a 100mm macro, I'd buy the 100WR. I find that I don't use the limiter and clamp very often since I MF most of the time doing macros, but I would find the metal construction and WR enjoyable and useful. Image quality wise, any of the 100s are outstanding.
02-20-2014, 04:28 PM   #21
Eder's Avatar
does anyone knows if filter is special or is normal for D-FA. Cuz i read on a page that filter is non-rotating for this lens, is this true or not
http://www.photozone.de/pentax/129-pentax-smc-d-fa-100mm-f28-macro-review--test-report
Can i use a std 49mm fitler or must be non rotating?
02-21-2014, 05:44 AM   #22
bdery's Avatar
Hello Eder,
I'm not sure I understand your question. I think you wonder if any filter will fit on the DFA WR macro lens. If so, the answer is yes, as long as it's 49mm. When people say a lens is non-rotating, it means that the front element of the lens does not rotate as you zoom or focus. So you can use a polarizing filter (which must be rotated to do its work) without worrying about loosing your settings.
02-21-2014, 10:01 AM   #23
Eder's Avatar
Autofocus non-rotating
Hello Eder,
Hi bdery thanks for you answer. Pentax user's manual says that when using autofocus, lens do not rotate. so this means that i need a non-rotating polarizer filter when i use autofocus?
02-21-2014, 11:27 AM   #24
bdery's Avatar
QuoteOriginally posted by Eder Quote
You got this backward a bit.
Independent of any filter, a lens's front element might rotate or not, depending on the design of the lens. Cheaper lenses will often have a rotating front element.
Now most filters are fixed (UV, ND, coloured, etc). However, some filter types, among them polarizers, have a rotating element. This is part of how they operate, not related to their quality or anything else. Again taking a polarizer as example, it needs to rotate to adjust its effect in relation to surrounding conditions.
Now, imagine you set your polarizer by rotating it, then you focus your lens and the front element rotates, messing up with how you adjusted your polarizer. That,s annoying... This is why most manufacturers will see "non rotating front elements" as perks and will list that feature on spec sheets.
That's all there is to it.
02-21-2014, 12:23 PM   #25
Transit's Avatar
While studying the various versions of the Pentax 100mm macro, I came accross a strange anomoly. In the D FA 100 macro review, it states that all the Pentax 100mm macro models use the same tried and true formula. My question is how this can be true when the FA version weights almost twice as much as the D FA versions. 600 grams vs 340 grams The newer versions are also shorter and from reviews, not as sharp as the older version.
Thanks, Dave
Dave I think the FA what I call 'the beer can' was designed to disable assailants when swung
as well as serve up some of the sweetest colours and tones we could wish for
presumably design requirements shifted from personal safety with the D-FA's
Pete with the FA 100 and 50
02-21-2014, 02:22 PM   #26
QuoteOriginally posted by Roland303 Quote
I've got the 100WR, and as I walk around in the bush with it on my camera, I have to say that the large lens hood, attached to the outer barrel, is a boon for protecting the inner barrel from bumps. I guess the earlier non-WR DFA lens had the same arrangement.
02-24-2014, 04:17 PM   #27
jddwoods's Avatar
I have the DFA 100 WR and could not be happier with it. It is a little long for botanicals (that is where 35 Limited comes in) but it is perfect for butterflies, dragonflies, hummingbirds and moderate telephoto. I don't miss that there is no limiter or clamp. Quick Shift is one of the best features of the newer versions. My one complaint was that while the outer barrel is solid metal construction, the inner barrel is plastic. That is OK but the filter threads seem thin and potentially easily damaged. I put on a digital ultra clear filter and now don't worry about that anymore. Now the most vulnerable part of the inner barrel is also metal. Also the hood is very convenient, lightweight and adds a measure of protection. Sharpness? I cannot imagine anything better. It is my sharpest lens and I have some sharp lenses 21, 25 and 70 mm limiteds.
100mm, fa, fa 100mm macro, fa vs, k-mount, macro, pentax, pentax lens, slr lens, version, versions, vs, vs d fa
Comparison of photographs. DA 18-135mm/3.5-5.6 , DA 70mm, Carl Zeiss 28, 50, 100mm Mr. A.S. Pentax SLR Lens Discussion 35 12-06-2010 08:29 AM
A quick comparison Tak 100mm F4 vs Tak 105mm 2.8 eccs19 Pentax SLR Lens Discussion 3 09-19-2010 06:06 AM
100mm f2.8 macro FA vs new 100mm mavro f2.8 DA stemked Pentax SLR Lens Discussion 19 08-23-2010 01:34 PM
Streets My first Macro lens, the DFA 100mm Macro WR. Here are my 1st few shots with it! aaronius Post Your Photos! 4 04-30-2010 07:23 PM
For Sale - Sold: [Worldwide] Promaster 100mm F3.5 Macro with 1:1 Macro Adaptor dgaies Sold Items 7 02-13-2010 05:37 PM
All times are GMT -7. The time now is 08:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
