Originally posted by RioRico It's easier to take two steps forward with a 15 to get a 21's AOV, than it is to step back with a 21, especially if cliffs are nearby.
this is a function of whether the cliff is in front of you or behind
the same holds true in cities, except the cliff is a busy road you step onto.
Regardless, my experience is "wider is better" and not to knock the 21mm, but that focal length is only moderately wide on an ASP-C sensor. I fought for years on film with a 24mm and it was never wide enough for landscape or archetecture, and when I got my *istD it came with the FA-J 18-35. I rarely used that lens on digital except for people shots indoors. outdoors that lens lived on my PZ1 at 18mm, because the FOV was considerably different than my 24 on film.
Now I use a 10-20 or a 14mm prime (samyang actually) for really wide shots
take the 15, you'll use it more, but even it i snot as wide as you will want
