05-15-2011, 03:16 AM   #1
Cost of lens calibration in Japan
I have a 21mm Limited that I picked up used. After shooting with it a bit, the images appeared a bit soft so i decided to use the AF Fine Adjustment (Pentax K-5) to calibrate it. With a setting of +10, it's not quite enough to get it into calibration. Does anyone here know how much Pentax Japan charges to calibrate a lens?
05-15-2011, 04:52 AM   #2
wlachan's Avatar
I doubt very much anything can be done to the lens. What they will do is to program your K-5 memorizing "that" DA21 and compensate by the software.
05-15-2011, 05:02 AM   #3
philippe's Avatar
The DA 21 mm is a little strange, it is more 'served' by sharpening in post processing than by AF calibrating.
I had the same thing and first started to adjust in the body but wasn't satisfied whit it, got a second copy, and the same 'softness' happened, so I tried the PP way and now it's OK...
05-15-2011, 04:20 PM   #4
Sharpening seems like a bad workaround since the issue isn't how sharp it is where it is focused. The issue is that the point of sharp focus is about 1 cm behind the object I am focusing on.
bit, calibrate, calibration, japan, k-mount, lens, lens calibration, pentax, pentax lens, slr lens
Rough Cost of Lens repair (and place to do it) jag0 Pentax Film SLR Discussion 3 02-14-2011 05:01 PM
Lens calibration Mortox Pentax K-5 4 01-05-2011 06:25 PM
Lens / Camera Calibration Hey Elwood Pentax SLR Lens Discussion 7 10-13-2010 12:15 PM
Nature this lens cost me 0.99 JesusOutlaw Post Your Photos! 3 05-31-2010 06:29 PM
K-x lens calibration, how? clipsed Pentax DSLR Discussion 3 02-10-2010 10:06 AM
All times are GMT -7. The time now is 04:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
