Originally posted by dadipentak Yeah, it was an interesting thread--until Stone G had to go ruin it with mathematics.
Ok - no math.. .
There are two ways to get an image in focus
- use a particular focal length lens and vary the lens' distance from the sensor (old way)
- use a particular distance from the sensor and vary the lens' focal length (new IF way)
There is no guaranteed advantage to either of which I'm aware. Except maybe long IF lenses can be smaller and lighter than nonIF lenses.
Say we have two 100mm lenses: one purely IF and the other nonIF; when they are both focused at infinity the focal length of both is 100mm. When focused closer than infinity, the nonIF lens is moved away from sensor to bring the subject in focus, while the IF lens' internal elements are re-adjusted to a smaller focal length to bring the subject into focus.
I believe that most IF lenses actually change both the focal length and distance from the sensor simultaneously. A Zoom lens is a type of IF lens in that the focal length and distance to the sensor are changed simultaneously.
There is no magic going on; when two lenses are stacked a new, compound lens is formed. The new lens has a focal length that depends on the original focal lengths and on the distance between them. So if you
move one lens with respect to the other the focal length changes.
There is no image or magnification created by an IF lens that can't be created by an equivalent nonIF lens although for the IF lens you won't usually know the actual focal length for a subject not at infinity (you could maybe calculate it if you want.)
See my next post regarding a difference in magnification/perspective)
