05-21-2011, 07:21 AM   #16
When everyone seems to say the da 35 has a slow auto focus, how slow is slow? Could you focus kids moving around at a park, or are you limited to static objects?
05-21-2011, 02:24 PM   #17
QuoteOriginally posted by yusuf Quote
I would go with 35+100mm combo.
50-135mm is a nice lens but does not match the quality of above combo. Not to open a can of worms, I had an opportunity to test 50-135mm before I bought 70-200mm and personally I found 50-135mm a bit soft wide open.
The only real negatives to the 50-135 vs. those primes would be greater size and weight and not-as-close focusing. Many primes will AF faster, too, but those two, not so much. The 50-135 is most definitely not soft. Sharp IQ is perhaps it's greatest strength. If you experienced softness, you either had a lesser copy or something else was going on.
I consider myself a prime guy, but there are instances when zooms are nearly irreplaceable. We are fortunate that Pentax makes some excellent zooms, and the 50-135 is certainly one of them. That being said, I wouldn't fault anybody for choosing primes instead.
05-21-2011, 02:45 PM   #18
psychdoc's Avatar
QuoteOriginally posted by chiane Quote
Me personally I have a hard time with the da 35 and moving kids. Its ok if you are standing at a dsitance, otherwise not so great. Maybe better technique could change things some. But I have read at least one detailed review where the reviewer said the exact same thing:
Pentax SMCP-DA 35mm f/2.8 Macro Limited User Review « robertsdonovan.com
"This incredible focus range (infinity to 0.139M) is the DA 35 Macro’s Achilles heel. It is very deliberate and accurate when shooting macro but becomes slow and laborious when taking snap shots. If the camera misses the focus point it will usually run all the way to one extreme of the focal range and then back to the focus point where (hopefully) it will lock on. If not, it will continue on to the opposite end of the focus range before heading back to try again. On a normal lens this “focus hunting” can be a bit annoying as the lens “ziiiip-ziiiips” back and forth before locking focus. On the DA 35 Macro focus hunting goes more like “ziiiiiiiiiiiiiiiiiiiip, ziiiiiiiiiiiiiiip, ziiiiiip, ziiip-zip.” I missed a ton of snap shots with the kids while this lens oscillated back and forth the focus scale on me.
Don’t misunderstand me. I’m not saying the focus isn’t accurate. As all Pentaxians apparently already know, their DSLRs do not have the fastest autofocus system. The DA 35 Macro exacerbates this problem considerably. Its deliberate focusing is an important feature for shooting critical macro shots in controlled conditions but is also the main reason why it isn’t a replacement for standard lenses for every day use. IMO there’s nothing wrong with being good at what you do and sticking to it".
Apart from this one fault, this is a great lens...
k-mount, pentax lens, slr lens
DA* 50-135mm versus Tamron 70-200mm Tommot1965 Pentax SLR Lens Discussion 31 11-08-2010 04:02 AM
FA 31mm f/1.8 versus FA 35mm /f2 - That old debate again pentaman Pentax SLR Lens Discussion 21 11-28-2009 02:47 AM
DA* 50-135mm vs. D-FA 100mm AF? MidwestMax Pentax SLR Lens Discussion 22 06-22-2009 08:58 AM
Bokeh challenge: 77 Limited versus DA*50-135mm!!! mikerigel Post Your Photos! 6 09-01-2007 10:51 PM
All times are GMT -7. The time now is 09:42 PM. | See also: NikonForums.com, part of our network of photo forums!
