Originally posted by mhaws My budget is pretty low right now. I have about 300 to spend on lenses, but was going to put 200 of it toward a portrait lens with automatic features. the automatic is less important for my wide lens since I will be shooting still objects or just presetting it and letting it stand on the tripod for the video.
As mentioned, that's just not a viable budget. But I'd also suggest that portrait lenses are ones where you don't normally need AF - after all, AF can't decide if you want to focus on the eye or the nose, and that often matters. Plus, subjects aren't moving, so you all the time in the world to focus.
So if you're trying to keep costs down, the way to do so will be to get a manual portrait lens, but an AF wide angle, simply because there really aren't many older lenses that are wide angle on APS-C. Consider, a 20mm lens was already insanely wide on film, but it's only barely wide on APS-C. if you want a lens wider than the kit lens, it will almost certainly turn out to be one made specifically for digital, and that means it will just as likely be AF. The few older lenses wider than 18mm tend to be collectors items and not cheap.
The one exception is the Zenitar 16 fisheye, which if you don't mind doing PP to correct the perspective might be worth a look.
