Originally posted by SirJangly Thanks dgaies. That sounds like a big problem :\ Is this common in only this lens, other tamron lenses, or lenses in general?
I don't know if I'd call it a big problem, but you should keep it in mind if you are buying a used lens without a return policy, especially if you can't be assured from the current owner that there are no major issues.
Overall, it seems to be a bigger issues on certain lenses more so than others. In general, most lenses can always benefit from a small adjustment. The issue becomes when they are way off and/or you have no way to correct for it. From my personal experience I've had far more trouble with getting a good copy of the Tamron 17-50 as opposed to the Tamron 28-75. I've never had a major focusing issue with any of the three copies of the 28-75 I've owned at different times. I can't say the same for the 17-50.
