Quote: But I could get by on the
28mm
50mm
105mm macro
135mm
200mm
300mm
Dawg
I can probably get by with something like that, although could probably do without the 300mm for now. That's more birdwatching range, isn't it?
Quote: Yes, but you can also use Av mode, which saves you from using the AE-L button. If you have a non-M (eg an M42) then you have to stop down meter:
1) focus wide open
2) stop down and meter
For various obscure reasons the metering for M42 lenses are usually out by about 2EV, so you have to apply exposure compensation or (if in M) alter the shutter speed given by the AE-L button.
What?! You mean I've been pressing the AE-L button this while time while Av mode... and I didn't have to? Haha... my bad! or maybe my good... now I know how to meter manually!!
Quote: Ah but what about losing quite a few shots because the DA lens is not as good as old glass? ;-)
You know, strangely enough, the M 28mm F2.8 took some amazing shots... absolutely amazing. Super sharp landscape pictures and family pictures, even close up portraits! The DA is a great lens, but I notice that there's less 'feel' to it when manual focusing so it's hard to manually focus properly. There's a bit more of a greasy resistance on the M lens, something that makes manual focusing much more accurate and enjoyable, not to mention that it takes more turning to go from one end of the focus to the other.
I'd still use the DA limited pancake lens when things get hairy and the autofocus is really needed (difficult to manual focus on super speedy zebra danio fish!), if I need P-TTL flash, or even if I just need the focal length. Plus, the size of the lens means less torsional force on my hand and wrist (easier on the hands). It's a great lens that can take some really awesome pictures. Plus, it's fun when other photographers ask 'where's your lens?' and you point out it's right there on the camera.
But I'm starting to manually focus on everything as complex focusing situations usually confuse the autofocus system.
Quote: Just this morning I was thinking of how happy I am especially on the mf/film side with my Program Plus: smc-a 28/2.8, Tamron SP 90/2.5, the Tamron 2x, and the 43 Limited. Just about perfect (adding in the Tamron SP 35-80 2.8-3.8 for good measure)....
Tamron 90 would be an excellent lens for my range! Is it a K-mount?
