05-23-2011, 06:48 AM   #16
QuoteOriginally posted by krypticide Quote
Should I sell them both and get the FA 31mm?
Practically probably no,but if you have this itch you need to scratch then do it.I have it but I'd probably sell it before the 77. It surprises me how often when scrolling through thumbnails(mostly to cull,room on the h/drive)how often I get pulled up by a photo,check the metadata an it's the 77.As a lot say here though check to see what fl you use mostly,having said that sometimes a new fl will take you places you did not think of going.
05-23-2011, 07:28 AM   #17
I second (make that third) Rondec, a combination of the DA* 55 and FA 31mm.
That's where I'm headed: DA 15mm, FA 31mm, and DA* 55mm.
05-23-2011, 07:41 AM   #18
I am on a different route and I am planning to own a 43mm. I myself have a sigma 30 1.4 and I think it's very good with low light situations and the FL is perfect for indoor. I will use the 43mm as a portrait instead of the usual 50-55mm and 15mm should complete my basic trif-lense collection
05-23-2011, 11:49 AM   #19
krypticide's Avatar
Great thoughts! I want something wider than 35mm but also reasonably fast. I defaulted to the 31mm since that's just one of the Exalted Three. The Sigma 30mm F1.4 is intriguing, but is larger and may or may not have the Limited "pixiedust".
Do owners of the 55mm F1.4 think it has "pixiedust"?
05-23-2011, 11:55 AM - 1 Like   #20
paperbag846's Avatar
Depends on what you want to do.
The 31 is going to give you a normal, and the 43 a long normal. Pretty close together. They do render quite differently, but if you are looking at shooting portraits, maybe consider something longer (70/77), or something even wider (e.g., the 21).
I would imagine something like the 21 / 43 / 77 or 70 would be more useful in practice, even if the 21 does not really compare to the 31.
05-23-2011, 12:28 PM - 1 Like   #21
nulla's Avatar
My opinion only
I have the 3 amigos and my most used and favourite of the three is the FA43.
cheers
Neil
05-23-2011, 02:48 PM   #22
Blue's Avatar
QuoteOriginally posted by paperbag846 Quote
I think if people took the time to learn the DA 21mm ltd, they would appreciate it. Don't be afraid to get close with it.
05-23-2011, 02:59 PM   #23
RioRico's Avatar
As I said in a similar thread, I would keep the FA50/1.4, or consider something of similar speed. Speed DOES matter. Very fast lenses can just do things that others can't. In fading light; when a shot MUST be captured; when the thin DOF is critical; then, nothing else will do. My FA50/1.4 is most often in my carry-bag, awaiting the right moment.
05-23-2011, 03:03 PM   #24
Blue's Avatar
I have it or the A 50/1.2 but most often the FA. If I get rid of the FA, I'd have to get either an F 50/1.4 or the DA* 55/1.4.
05-23-2011, 03:20 PM   #25
krypticide's Avatar
Interesting. That's why I'm kind of sad the DAs all have relatively small apertures. I realize the lenses were designed with size in mind. Maybe I should look outside the Pentax brand.
I guess the only way I can see if I like the 31mm focal length is to set my 16-50mm roughly there and pretend I see a shallow DOF. ;-)
Sent from my EVO 4G with MIUI
05-23-2011, 04:16 PM   #26
Yes, it's a sad fact (although with the 70 is nearly close enough, and with the 15 it's really a non issue).
The FA lenses (non-limited) have lot of really good options, if you are comfortable with buying used.
I really hope the DA lenses get a little faster... even if they are larger.
05-23-2011, 05:06 PM   #27
I don't really know. All I know is that it is sharp from f1.4, has good color and Bokeh is good from f2 on (not bad at f1.4, but not that good either). I just think the focal length would be more useful in conjunction with the FA 31 than the FA 43.
I think that there have been some bad copies of the lens out there that have resulted in some negative opinions on it, but in my opinion, a good copy is definitely at FA limited level of sharpness. The only real negative to it is that the focus is on the slow side due to a really long focus throw.
05-23-2011, 06:33 PM   #28
I own the FA 77 and I can tell you it's just a very good lens, no pixiedust to be found.
The 55 1.4 is also a very good lens. The only reason it's not a limited is because it's weather resistant, SDM, and therefore, larger.
If you were going to grab the 55, I might wonder if you should do a 15 - 31 - 55 - 77 or something of the like.
05-23-2011, 07:13 PM   #29
Yeah, that's a killer setup IMHO.
05-23-2011, 08:11 PM   #30
Lots of focal lengths in the title...but it says it all.
My latest lens acquisition was the 43mm, which I absolutely love. When I want a prime on my camera, I always think of the 43mm. So the FA 50mm and FA 35mm aren't feeling any love. Should I sell them both and get the FA 31mm?
Despite the FL's being relatively close, the 31 and 43 are sufficiently different lenses that owning both is by no means superfluous. I would indeed get the 31 since you have two lenses to sell and offset the cost somewhat. If you turn out to have a clear favorite between the 31 and 43 you can sell the other and move on to the 77 or the 55. All are wonderful.
Each of the three amigos has fans that consider it the best of the bunch, no matter what papersack says. The 55 was designed by Pentax's most accomplished lens designer, so there should be no surprise that it too is a top-notch lens, though it does have a bit different personality than the FA Ltds.
There's a good used market for all of these lenses so you're really not risking much by trying them out. Enjoy the journey!
43mm, 50mm, fa, k-mount, love, pentax lens, slr lens
For Sale - Sold: Pentax FA 31mm/FA 43mm/FA 77mm/DFA 100mm/DA* 16-50mm/ DA*50-135mm/DA 55-300mm loveisageless Sold Items 24 03-01-2011 03:51 AM
For Sale - Sold: Pentax FA 31mm/1.8, FA 43mm/1.9, DA 35mm/2.8 Macro, DA 12-24mm, AF160 flash (U farfisa Sold Items 15 12-10-2010 02:00 PM
For Sale - Sold: Pentax Sell Off Part 3: FA Limited 43mm and 77mm k100d Sold Items 14 11-04-2009 06:31 AM
All times are GMT -7. The time now is 01:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
