05-23-2011, 10:42 AM   #1
my old DA 50-200mm lens not work
Hi Everyone,
My old 50-200mm lens was with my old K10D 4 or 5 years ago, Now Use my K-7 use it since.
Today I put 50-200mm on my K-7 but I see viewfinder is black and AF is not work. I was worry about my K-7 but K-7 work fine with my other lens prime.
Why 50-200mm lens not work. it dead. How can i do it? or whatever?
Thanks.
05-23-2011, 11:37 AM   #2
Marc Sabatella's Avatar
If the viewfinder is dark, there are two possibilities:
1. the aperture mechanism is stuck / broken so the lens is staying fully stopped rather than opening when mounter
or
2. you forgot to take the lens cap off
Assuming it's not #2, you can test #1 by taking the lens off and looking through it as you work the level with your finger - do you see the aperture blades opening and closing?
05-23-2011, 12:47 PM   #3
No cap on it. Smile
50-200mm lens won't work AF and little dark in viewfinder.. I think it broke inside lens and no good. My other lenses are work fine.
05-23-2011, 01:18 PM   #4
Nowhere Matt's Avatar
So are you suggesting that you have tried working the little mechanism on the lens mount and the aperture does not open and close?
If you end up needing to replace the lens, do yourself (and forum members) a favor and just find a good price for the Pentax DAL 55-300mm and consider the matter closed.
50-200mm, da 50-200mm lens, k-7, k-mount, lens, pentax lens, slr lens
Does the Vivtar 80-200mm F4.5 lens work with the Pentax K-x? mojoe_24 Pentax DSLR Discussion 14 01-11-2011 02:14 AM
how do i know if a lens will work with my k-x? jupzchris Troubleshooting and Beginner Help 17 08-01-2010 09:52 AM
Will this lens work with K-x? pakuchn Pentax SLR Lens Discussion 7 12-29-2009 12:23 PM
My Tamron 70-200mm f/2.8 is in for warranty work... heliphoto Pentax SLR Lens Discussion 14 03-26-2009 11:52 PM
Looking for an affordable zoom (~200mm) for auto-racing work... The Motorist Pentax SLR Lens Discussion 8 12-16-2008 02:53 PM
All times are GMT -7. The time now is 05:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
