05-23-2011, 06:13 PM   #1
DaveHolmes's Avatar
Is the field of view for the DA40mm the same as the'M' version
I just wondered... I have the M-40mm f2.8 on my MEsuper and its a 'fairly wide field of view (I like it) but when it's on my K-x it's considerably narrower so I tend to use the FA50 1.4 instead as it's simply just a better lens...
Obviously he DA-40mm as a limited lens has a better optical formula but do they have the same field of view when mounted on a modern pentax dslr?
M-40 2.8... built originally for film... As is the FA-50mm
DA-40mm Limited... built for cropped sensor dslr...
Surely the field of view is wider on a lens designed for cropped sensor than that designed for full-frame or film...
Cheers
Dave
05-23-2011, 06:29 PM   #2
yes - the same.
05-23-2011, 06:30 PM   #3
wshi's Avatar
Nope, 40 is 40. So with the 1.5x crop, it's more like a 60mm fov on a Pentax dslr.
05-23-2011, 06:39 PM   #4
QuoteOriginally posted by wshi Quote
both 40s will look the same on DSLR, which is the point. 40 is 40.
05-23-2011, 06:56 PM   #5
Blue's Avatar
The DA 40mm ltd will work on autofocus bodies with in body aperture control. The DA and M will have the same fov on a film body and the same fov on a dSLR. It is the sensor that is changing the fov, not the lens.
05-23-2011, 07:06 PM   #6
DaveHolmes's Avatar
That made sense... Cheers Blue :-)
I shall make sure to play with the 'M' version' before I make any LBA decisions...
05-23-2011, 09:52 PM   #7
Banned
QuoteOriginally posted by DaveHolmes Quote
The M is a pretty good lens. Has some ugly PF sometimes, but otherwise it is very sharp wide open and produces some interesting colors.
@f/2.8:
[link]
06-06-2011, 12:59 PM   #8
DaveHolmes's Avatar
Just an update... Been playing a little with the M-40-f2.8 on the K-x... Not had great results to be honest... And keep switchin back to the FA50... As such I'm finding the 'narrowness' of the fifty less and less of an issue the more I use it...
Still want an AF-prime thats considerably wider than 50mm but its going to have to wait a while... Although heavy the Tamron 17-50-2.8 does (admirably! just the size and weight!!) the job for now...
Cheers all
Dave
field, field of view, k-mount, lens, pentax lens, sensor, slr lens, view
Field of view with small sensors Spring Creek Troubleshooting and Beginner Help 7 07-24-2010 06:48 AM
plots of focal length vs. field of view rparmar Pentax SLR Lens Discussion 34 05-21-2010 02:02 PM
Okay Guys, Confusing Field of View joodiespost Troubleshooting and Beginner Help 9 01-11-2010 07:57 PM
Field of view Opahujo Pentax SLR Lens Discussion 9 12-04-2009 09:50 AM
standard view of field? gokenin Film SLRs and Compact Film Cameras 11 09-28-2009 07:45 PM
All times are GMT -7. The time now is 12:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
