Originally posted by jstevewhite Not sure what color space you're using, but on export, make sure you set color space to srgb, as IE and Chrome don't support color profiles by default.
It's very frustrating that my web images don't look like they should, so thanks for your help. Maybe you could try to walk me through this. We'll use the first image I posted:
And here is the metadata as displayed in Adobe Bridge CS5 from the original DNG RAW file showing that the "Color Mode" is RGB and the "Bit Depth" is 16.
Now when I take the image into PhotoShop CS5, the color mode shows "RGB Color" and "8 Bits/Channel":
And when I save the final image as a JPEG, I see a check box for "ICC Profile: Adobe RGB (1998)":
Unchecking that box doesn't seem to do anything. Here's the same image from above with the box unchecked:
Both images still appear de-saturated and flat in the browser when compared to the same image in PhotoShop. Do you see where I'm doing something wrong?
