05-28-2011, 06:27 AM   #16
Well, compressed focus isn't always a bad thing. I am mostly using old manual lenses and on Tair-3 300/4.5 you get about 360 degrees from 2.2m to infinity, and that's not the light action of modern lenses. Which makes it really tricky to use it for any kind of action shots.
06-23-2011, 08:02 AM   #17
QuoteOriginally posted by MJL Quote
Hi hjb981,
I am on the same boat! Manually focusing DA*200/2.8 is difficult as the focusing ring turn rather "quick", whereas the focusing throw on M200/4 is smooth & easy. 90% of my lenses are MF and can be use on my Kr, K5 & K7, but I find my focusing ability is way off from using the same lens on a film camera such as MX. Same apply to the AF lenses when I use MF on them. I shoot existing light a lot and this problem has really stumped me. Hopefully you can tell us whether a KatzEye helps in manual focusing.
It does help. I received it a few days ago, put it in, and thought everything was great after trying it with the DA 18-135 f/3.5-5-6 WR. Then I put on the good olīM 50 f/1.7 from 1978, and it was very apparent that the screen's position was not correctly calibrated. I bought a set of shims, and after trying found the 0.10 mm (the thinnest on - they go from 0.10 - 0.50 mm) to be the right one. The original shim in my camera was the 0.35 mm. Now, the screen is properly calibrated, and as a preliminary opinion, without yet trying it for real, it seems to me that this screen makes manual focusing much easier. Both with the center prism and with matte part of the screen, which is better than the stock screen's matte (the stock screen only has matte area for focusing). The screen I have is the KatzEye for Pentax K-5 with center prism, micro-prism collar, with optibright treatment and without markings for focus points etc
KatzEye swiftly sent me instructions on how to change shims, and in my opinion, changing the shims was easy - the hard part was still getting the focus screen out and in without scratching anything (which has to be done each time the shim is changed, btw).
focus, ft, infinity, k-mount, lenses, pentax lens, scale, screen, slr lens
Manual Metering on Pentax DSLRs with Manual and Automatic Lenses Adam Pentax DSLR and Camera Articles 20 01-06-2016 03:38 AM
Do you use only manual focus lenses?Do a lot of folks use only manual lenses? heralu Pentax DSLR Discussion 12 01-05-2011 04:06 PM
Focusing manual lenses on DSLRs Oro Troubleshooting and Beginner Help 14 08-28-2010 12:48 AM
Why only center point focusing for manual lenses? LightBug Pentax DSLR Discussion 19 01-01-2010 04:33 AM
Manual lenses K10D focusing screen Pentastic Pentax DSLR Discussion 2 08-11-2009 05:06 PM
All times are GMT -7. The time now is 08:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
