12-14-2006, 01:06 PM   #1
clarenceclose's Avatar
Anti shake manual mode w/close up
The mode for setting the antishake on a K100 or K10 allowes entry of the lense size (i.e. 50mm) but when you add something like a 250D or a 1/2/3 closeup lenses to the front of the camera, would that change the setting for the antishake manual entry? If so, to what?
12-14-2006, 04:32 PM   #2
Arpe's Avatar
Good point. And can you manually set the length even if using a DA lens?
12-14-2006, 07:09 PM   #3
joele's Avatar
I don't think you can set it with an A lens.. even with my tamron 1.4x I haven't found a way to change it..
12-14-2006, 08:48 PM   #4
Dana G's Avatar
It seems you need to enter the focal length information when using K, M, or A series lenses. Apparently, they don't transmit the focal length to the camera.
All the autofocus lenses seem to transmit the information to the body.
antishake, entry, k-mount, mode, pentax lens, slr lens
K-5 Anti-shake (image stabilization) test Skymist Pentax K-5 & K-5 II 24 03-26-2012 06:25 AM
More ??? About lens correction & anti-shake CDW Pentax K-5 & K-5 II 5 06-08-2011 12:09 AM
Broken Anti-Shake results in Focus issues volvomanny Pentax DSLR Discussion 2 01-18-2011 07:33 AM
anti shake on or off w/monopod Lance C Photographic Technique 4 09-26-2010 08:52 AM
[k-x]How to enable shake reduction in video mode with manual lens? tiny Pentax DSLR Discussion 9 03-15-2010 07:56 PM
All times are GMT -7. The time now is 06:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
