As a beginner, why not check out a pair of used, older lenses at the same time? Get something like an M 50mm and 100mm Macro...both should come in under $100 each and you can resell them without losing much, if any, money. They'll only do 1:2 magnification, but we all start somewhere. Heck, grab a cheap manual focus 35mm with a short extension tube...that should get you used to working with the DA35.
That way, you can decide if you want a short or long focal length. From what people have said, the 35Ltd has to be close to the subject...
super close..."up in the subject's business" one user said
Personally, I prefer 90-100mm. Using my teleconverter to make a 180mm lens didn't do much for me, and I kicked around the idea of a 50mm...but, once I sell all my Adaptall gear, I'll probably get the non-WR D-FA 100. The runner up would be the Tamron 90, but I'd buy the FA 100/2.8 over them all if I had $400-500.
That probably confuses things more than it helps
It's really hard to go wrong with most macro lenses. Budget, WR or not, focal length, magnification ratio, weight...those are the big decisions since all your options are good
A 35mm macro versus a 100mm macro is a personal choice, unfortunately, that will probably end in a 50/50 decision among commenters. Plenty of people are happy with the Limited which is great...it wouldn't be ideal for me, however.
When in doubt, buy used!
