05-29-2011, 11:45 PM   #1
MegaPower's Avatar
Is this chips fixable??
I recently found this lens and the owner is willing to let it go for cheap.
It's a A* 300mm F4.
How much effect it's going to show on the pic?
Is this fixable?
The one in the very middle
05-29-2011, 11:55 PM   #2
Those look like fingerprints/smudges, and can probably be cleaned
05-30-2011, 12:07 AM   #3
Where is the chip, is it the white dot slightly left of centre? If so it's probably not fixable but may have very little impact on the IQ unless you shoot in the minimal aperture settings like f22. Do a google search for broken lens pictures, you should see what some all but destroyed lens is still capable of.
Thanks,
05-30-2011, 12:09 AM   #4
axl
From that picture it's hard top say if there's any irrepairable damage but even if was, if you want to have THAT lens just take it, for the right price of course. The front element can take enormous damage before affecting IQ, so even with small scratch os so you'll be just finre...
05-30-2011, 12:15 AM   #5
MegaPower's Avatar
My bad.
It's the chip in the middle.
05-30-2011, 12:17 AM   #6
MegaPower's Avatar
QuoteOriginally posted by excanonfd Quote
Thanks,
I did.
I saw a lens cracked from the middle all the way to the end like a spider net.
It still takes good pics, except flares and sharpness.
I can't find any cases that someone is able to fix a chips tho.
05-30-2011, 12:38 AM   #7
QuoteOriginally posted by MegaPower Quote
I did.
There are some threads in the forums here that shows similar things, I just can't locate them. If the price is really right, I would take a chance at it. It's resale value will not be much but if you can get stellar images from it, it could be a bargain.
Thanks,
05-30-2011, 03:14 AM   #8
Hi
I had a lens with similar damage some years ago. During a car rally a small stone must have shot off a tire of a passing car and hit my lens like a small bullet. It left a hole perhaps a smidgen bigger than the one in your picture.
Pictures taken with this lens did not show any ill effect under perfect light conditions at other times however under certain light the white of the pulverized glass of the impact site did show up as a faint white shadow. (Can you have a white shadow?) I remedied this successfully by dabbing on (into) the hole a small amount of clear nail polish with a very fine pointed small brush. This made the white glass powder go clear. From than on I never had any problems with this lens.
Hope this information is of use to you.
Greetings
05-30-2011, 05:50 AM   #9
Kim C's Avatar
If the lens is cheap and you are happy with it, go for it. My suggestion would be to "spot" the chip with black paint. That will stop any flare or other effects coming from it and so the result will be a very negligable loss in "speed" perhaps less than a 1/10 of a stop
Kim
05-30-2011, 06:37 AM - 1 Like   #10
QuoteOriginally posted by Kim C Quote
Kim
Sorry I disagree.
Don't use black paint, if the spot shows up it will be more noticeable than the clear nail polish I suggested. I spent a lot of time experimenting at the time.
I put some water on the damage to make the white glass dust more transparent and stuck next to it a black paper patch of the same size (Because I had the same idea about the black and I wanted to find out before committing myself.) I than took a series of shots under a lot of different light conditions and angles. I can tell you that the water worked best, and when I put the clear nail polish on it was even better still.
Greetings
05-30-2011, 09:53 AM   #11
MegaPower's Avatar
I had similar idea but seems you put it to work.
I was thinking the windshield repair kit for car.
05-30-2011, 11:24 AM   #12
It's terrible, awful, buy it cheap and send it to me!
Seriously, way back when, I shot Proms with a Rollie medium format that had a bigger scratch than that and my pics were well reviewed. The scratch never showed on the prints.
05-30-2011, 05:05 PM   #13
Could be a goer as well but it is way too expensive. In the end it'll probably cost you more than the lens is worth.
To tell you the truth the trick with the clear nail polish I learned from an old news reporter friend of mine who was confronted with the same problem. At the time he used a certain jelly (let your imagination run wild) because he did not have any nail polish which he used later on.
Greetings
05-30-2011, 09:01 PM   #14
SpecialK's Avatar
It will have no effect on the image - only resale value.
05-30-2011, 11:45 PM   #15
MegaPower's Avatar
QuoteOriginally posted by Schraubstock Quote
Greetings
just FIY, The kit is about US$10-20 only.
but the nail polish looks easier to use.
k-mount, pentax lens, slr lens
Sports TOO MUCH NOISE is it fixable? ChallengedOne Photo Critique 18 04-03-2011 05:13 AM
I've got a tight ring, fixable? Arpe Pentax SLR Lens Discussion 5 12-12-2010 04:36 PM
How to compare AMD and Intel chips? barondla Digital Processing, Software, and Printing 19 05-10-2010 10:35 AM
K-x IQ- All that and a bag of chips! Rush2112 Pentax DSLR Discussion 21 05-09-2010 09:13 PM
Fixable problem, or ignore it? foxglove Pentax DSLR Discussion 10 12-30-2009 09:27 AM
All times are GMT -7. The time now is 02:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
