06-01-2011, 08:08 PM   #1
Wide angle lense
I am looking for a wide angle lense ( less than 18mm) for aorund 300 bucks. can anyone help me?
06-01-2011, 08:13 PM   #2
Marc Sabatella's Avatar
As you'll see if you search for the many other threads on this topic, there aren't a lot of choices in that price range. The Zenitar 16 fisheye is basically it for lenses significantly wider than 18 (being a fisheye, it feels much wider than other 16's). The DA16-45 is another possibility but not as wide. Beyond that, you need to expect to spend more for any of the various 10-20, 10-24, or 12-24 zooms, or the DA15 or DA14.
06-01-2011, 08:13 PM   #3
Ash
Community Manager
Ash's Avatar
Welcome to the forum.
I'm assuming you're looking for a lens to fit a Pentax dSLR.
If so, your options are limited to autofocus zoom lenses with 16mm widest focal length (i.e. DA 16-45) or a manual focus lens such as the Zenitar 16mm f/2.8 fish eye. Have a look through this forum's Pentax Reviews - Pentax Lens Reviews & Pentax Lens Database for more possibilities within your budget.
06-01-2011, 08:18 PM   #4
twitch's Avatar
Second hand Sigma 10-20 should be around $300
06-01-2011, 08:26 PM   #5
RioRico's Avatar
The Zenitar 16/2.8 (a bit fishy on a Pentax dSLR) is the most reasonable, probably around US$200. Using software to defish the images, it is equivalent to about 12mm.
I have seen users complaining of returning 2-3-4 Sigma 10-20's before getting a good copy. If you go that route, be certain that you can return the lens if necessary.
As mentioned, other WIDE options are not cheap, except the Vemar 12/8 fisheye, which has problems. If you want to legally obtain any but the Zenitar or Sigma, raise your budget.
06-01-2011, 09:52 PM   #6
reeftool's Avatar
For $300 and under you're looking at used glass. The Samyang 14mm is close to that new but manual focus.
06-02-2011, 09:39 AM   #7
thanx guys it helped alot
angle, k-mount, lense, pentax lens, slr lens
Finding the right wide angle AOShep Pentax SLR Lens Discussion 77 04-27-2010 11:25 AM
Confused - What wide angle lense? molko Pentax SLR Lens Discussion 6 03-25-2010 04:56 AM
People wide angle and kids uccemebug Post Your Photos! 9 10-08-2009 04:47 AM
AF and wide angle lenses opiedog Pentax SLR Lens Discussion 5 08-25-2009 12:59 PM
Need help picking a wide angle lense Moggman Pentax SLR Lens Discussion 21 03-14-2008 06:16 PM
All times are GMT -7. The time now is 10:14 PM. | See also: NikonForums.com, part of our network of photo forums!
