Originally posted by stormtech Thanks for the opinions so far -
I am familiar with using an M lens with my K20D using the green button for stop down metering - seemed to work fine with my M100 f4.
I am assuming I would use the same process with the K400 - am I right in assuming I would do the same with the 55BB mirror?
not quite, the K400 like the K500/4.5 are manual apertures, meaning yuu open the lens up to focus and stop down to shoot. You would probably be best at using it in Av mode, like an M42 lens
Quote: Just to be clear, the 55BB I am looking at is an M42 that would come with an adptall-2 K mount adapter plus the SP 2X Tamron teleconverter.
these can go pretty cheap, the mirror is a fixed F8 aperture I believe, so put it in Av mode unless you want to shoot manual
Quote: And yes, the K500 would be even better, but seem harder to find. Took a quick look on ebay and they seem to go for over $500. If I go that far, I would be happier with saving up for the Sigma 150-500.
I agree, also note the K500/4.5 also has a minimum focus of 35 feet. In hind sight, something to look at for the K400, as well, I think it is over 20 feet. this can be a problem with little birds, because you can easily get inside the MFD
Quote: I've been through the entire "mirror lens club" thread and I see very many super-sharp photos there without the donut brokeh.
yes they can be sharp i think the donuts are only really an issue for points that are not fully out of focus. If you can avoid bright highlights in the background you should be OK/ Mirrors also focus quite close compared to other lenses.
