06-06-2011, 12:18 PM   #1
Tricking Kx into thinking manual lens is A-lens
I have a 500mm f/8 mirror lens. I want the camera to think it's an A lens set to f8 so that PTTL flash will work. Specifically, I want my Sigma 610 flash to work in PTTL high-speed sync mode with this lens. Is this possible?
Charles.
06-07-2011, 06:02 PM   #2
selar's Avatar
Try shorting the lens contacts using aluminium foil or tape.
06-07-2011, 06:28 PM   #3
Lowell Goudge's Avatar
QuoteOriginally posted by ChopperCharles Quote
Charles.
with a mirror yes, it is possible
you need to look at the pentax pin assignment for max and min aperture and work out the coding for your lens, use nail polish to insulate the necessary pins. then, for th epin 3 location you need to get a spring loaded pin, I used a pin from a grid array IC socket, which was spring loaded, and inserted it into a mount to give the A contact (3rd location from the locking pin, and the only recessed pin on the camera)
06-07-2011, 07:17 PM   #4
Lowell,
I found small spring ball plungers on mcmaster.com http://www.mcmaster.com/#spring-plungers/=cngn39
How does one easily lay out exactly where to put it on the lens base?
06-07-2011, 07:40 PM   #5
QuoteOriginally posted by selar Quote
That's quite difficult to do in my experience because the A pin is recessed. I have heard of people who have managed to trap a small ball of tinfoil - but I've never been successful.
It is easy to modify the camera mount so it thinks that all lenses are A type by short-circuiting the mount's A pin as follows:
I've not found a downside to this mod & it is easy to reverse should a downside appear. It is not a dangerous nor difficult procedure.
The major benefit is that P-TTL works for all lenses.
flash, k-mount, lens, pentax lens, pttl, slr lens
Thinking about a new lens, would love some input. chrisb3 Pentax SLR Lens Discussion 9 05-25-2011 11:54 AM
lens question - manual lens won't fire wackymummy Troubleshooting and Beginner Help 7 05-21-2010 10:16 AM
Thinking on a new Macro lens. Advice? Ouroboros Pentax SLR Lens Discussion 15 04-15-2010 05:04 PM
Thinking of getting a new lens...what's your favorite? timstone Pentax SLR Lens Discussion 28 03-28-2010 01:05 AM
Kinda sorta thinking of a new lens... sebberry Pentax SLR Lens Discussion 10 08-04-2009 06:32 AM
All times are GMT -7. The time now is 01:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
