06-07-2011, 10:16 PM   #1
Pentax macro lenses greater than 1X magnification??
Are there any macro lenses for Pentax with greater than 1x magnification?
I have the DFA 100 WR which has been decent, but spotted a friend of a friend with a Canon E65 (?) or something that also increases the magnification up to a crazy 5x!
He was getting some great images from it, really quite abstracted, and made me a little jealous
can you only do this with extension tubes with Pentax? (if so, that will prove difficult with the DFA 100 with lack of aperture ring?)
06-07-2011, 10:33 PM   #2
Digitalis's Avatar
It can be done, and there are many ways and none of them are quite as easy or convenient as using the canon MP-E 65mm f/2.8
1) use extension tubes or teleconverters - and find our own way around the lack of aperture ring on your DFA 100mm f/2.8 WR Macro
2) reverse mounting lenses together E.G a 50mm f/1.4 and a 100mm f/2.8 will give you about 2X magnification.
06-07-2011, 10:48 PM   #3
Pentaxor's Avatar
or just stack up some close-up lens like the Marumi on your macro lens and you will get the magnification like your friend did.
06-08-2011, 03:57 AM   #4
thanks, will look into both suggestions!
I have an FA50/1.4 but as I understood, the lack of aperture ring on the DFA100WR was a problem
06-08-2011, 06:08 AM   #5
Blue's Avatar
QuoteOriginally posted by JayR Quote
You can control the aperture on the DFA WR with the dial in Av or manual. But to clarify, there are no Pentax macro lenses with greater than 1:1. To get there requires extension tubes, bellows, lens reversal, or stacking etc.
Edit: That Canon MP-E 65 is a nice glass, but it doesn't do infinity focus and it isn't auto focus and it too lacks an aperture ring.
06-08-2011, 06:27 AM   #6
RioRico's Avatar
Your DFA100WR's lack of an aperture ring needn't be a problem.
It IS a problem if:
1) you reverse that lens with a mount-reversal ring (which isn't a good idea), or
2) you mount that lens on non-A-type extension (bellows or cheap tubes).
It ISN'T a problem if:
3) you use supplemental optics (closeup adapters, or a reverse-stacked lens), or
4) you mount that lens on A-type extension (macro tubes or de-glassed TC's).
The cleanest way to get more magnification is with extension. AF tubes or TC's ain't cheap, but AF is not your friend when shooting macros. A-type tubes cost less; used A-type TC's cost even less, and function as tubes when their glass is removed. But with a 100mm 1:1 macro lens, you need another 100mm of extension to reach 2:1. That gets clumsy. But you have plenty of working distance.
Then there are supplemental optics. The easiest way to shoot closer is to use cheap closeup adapters, those ubiquitous +dioptre meniscus strap-ons. Costing a bit more, but with cleaner results, are corrected closeup adapters like the Raynox DCR-150 (4.8dpt) and DCR-250 (8dpt). These adapters just shorten the working distance.
Reverse-stacking can provide much greater magnification. But it's best if both the long primary (mounted on the camera) and the short secondary (reverse-stacked onto the primary) DON'T have deep front insets. All my macro camera lenses have such insets, so I don't use them that way. Also, reverse-stacking primes means your working distance is ~45mm, under 2in.
IMHO your best, cleanest options are:
1) Some A-type extension for magnification under 2:1
2) A Raynox or other closeup adapter for easy closer work
dfa, friend, k-mount, lenses, macro, magnification, pentax, pentax lens, slr lens
Magnification and Macro Ratio Thales454 Pentax SLR Lens Discussion 12 05-03-2011 03:11 PM
How does magnification of lenses compare to P&S cameras? mojoe_24 Troubleshooting and Beginner Help 3 01-12-2011 08:54 PM
Fast (f/2.0 or greater) Macro lenses available in Pentax K mount? Edgar_in_Indy Pentax SLR Lens Discussion 37 12-09-2010 09:17 PM
[macro] Computing magnification? miks Photographic Technique 7 10-25-2010 05:42 AM
Lenses, Bellows and Magnification void7910 Troubleshooting and Beginner Help 13 08-13-2010 10:28 PM
All times are GMT -7. The time now is 10:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
