06-08-2011, 07:40 AM   #1
My replaced 16-50, an your opinion about
Hello friends, this my new 16-50 repaired, i would an your opinion about if this is accettaple for 16-60 or not: the right side appears slighty soften in some images:
on tripod, sr disaled:
image 1, 43mm f5
image 2, 43mm f4
image 3 36mm f4 (perfect)
image 4 36mm f4
image 5 50mm f5.6
free hand:
image 1
22mm f3.5 (looks perfect)
image 2 24mm f3.5 (soft on the right)
Any images are soft on the righ, others perfetc in a casual way.
This appears strange to me, the problem is only at infinite focus.
But probably is only my impression.
What do you think? Is accettable for a 16-50?
ps.: location south Italy.
06-08-2011, 07:45 AM   #2
Looks good to me. May be that's a focus plan because of that it's appearing a bit soft on the right.
Can you please post image at 16mm, just like to know if it has any barrel distortion like my tamron 17-50
06-08-2011, 08:04 AM   #3
Edgar_in_Indy's Avatar
The aggressive image compression makes it difficult for me to judge absolute sharpness.
Also, in all of the pictures, objects on the right side of the frame are farther away from the camera than are objects on the left side (if that makes sense), so it's hard to compare one side to the other.
06-08-2011, 08:15 AM   #4
An image slightly compressed :
Image 6 43mm f5.6
An image at 16mm for yusuf:
image 16mm
06-08-2011, 09:16 AM   #5
Try taking some shots at 90 degrees to a wall, ideally brick construction. Should give you something better to judge.
06-08-2011, 10:41 AM   #6
QuoteOriginally posted by manowar1978 Quote
Image 6 43mm f5.6
image 16mm
Thanks manowar, 16-50 is stellar.
06-09-2011, 03:30 PM   #7
Add others 2 photos of a wall:
image 7 39mm f5.6
image 8 39mm f3.5
06-11-2011, 05:10 AM   #8
Sorry, but I don't see much charpeness or contrast anywhere.
Also a bit muddy colors and a lot of purple fringing.
My oppinion: sent it back while you still can.
06-11-2011, 05:42 AM   #9
selar's Avatar
this 16-50 is fine.
43mm, f3.5, f4, image, images, k-mount, opinion, pentax lens, slr lens
Replaced focus screen, some questions ChopperCharles Troubleshooting and Beginner Help 8 04-06-2011 06:25 AM
Replaced K5: Tested for FREEZING psychdoc Pentax K-5 9 03-28-2011 05:20 PM
Can the USB port rubber cover be replaced? peterh337 Pentax K-5 2 01-26-2011 12:23 PM
replaced K-5 - no issues left elho_cid Pentax K-5 13 12-21-2010 05:09 AM
Got my 16-50 replaced; now sending it AND the K-7 in for repair inferno10 Pentax DSLR Discussion 15 08-16-2009 12:42 AM
All times are GMT -7. The time now is 10:02 AM. | See also: NikonForums.com, part of our network of photo forums!
