06-08-2011, 10:13 PM   #1
Cregar's Avatar
KR mount Lens
Im looking at a Sears 135mm lens but it says it has a KR mount.... not sure what that is, will the lens mount to a K20D??
Thanks fro any help
06-08-2011, 10:21 PM   #2
wizofoz's Avatar
It is a Ricoh/Rikenon K mount lens. It will mount but.......
Be very very careful of the 'Ricoh pin'
The difference between K mount and KR is a tiny pin which has no use on a Pentax camera, but may get caught in the AF drive of the K mount and get the lens stuck on your camera.
The pin can be removed if you are game enough to open the lens, or ground off using a small Dremel or similar.
06-08-2011, 10:34 PM   #3
Yes, it should be very easy to remove the lens back plate from your lens and get rid of the offending pin (by the way, it's the one more or less diametrically opposite the red dot). The dremel sounds a bit nasty (and unnecessary) to me.
Do not be tempted to mount it on your camera until you've done this!
06-08-2011, 10:37 PM   #4
Cregar's Avatar
Cool.... thanks for the advice.
06-09-2011, 06:44 AM   #5
RioRico's Avatar
Bear in mind that there are two varieties of Ricoh pins -- the actual protruding pin, which should be removed; and a rounded nub, which is no trouble. I have never encountered the toxic pin. I have read that if you hold a KR lens and manipulate the aperture ring and levers, the pin will extrude. So, that's a test to see if you need to pull the lens apart, remove the pin, and reassemble. Various threads here discuss that minor surgery. Good luck!
06-09-2011, 09:06 AM   #6
It's a snap to remove the Ricoh pin. Takes 5 minutes. Here's how:
theatre of noise: Ricoh Lenses On Pentax Cameras -- The Ricoh Pin Fix
Cheers,
Bobbo :-)
06-10-2011, 07:27 AM   #7
QuoteOriginally posted by GibbyTheMole Quote
Cheers,
Bobbo :-)
Bobbo: Thanks for the link. I need to remove one of those soon.
12-27-2018, 11:06 AM   #8
Stuck
I have taken the lens from my (late) brother in laws K1000 and tried it on my Ks2, it is now stuck, how do i remove it with out killing anything
12-27-2018, 03:20 PM   #9
QuoteOriginally posted by pilgrim_monkey Quote
Before I learnt there could be a problem I made the same mistake, ending up with a Ricoh-mount lens apparently "permanently" mounted on my Pentax camera.
Some frenzied research later led me to the conclusion that if the pin on the lens had dropped into a recess on the camera, the only thing that was likely to get damaged was the lens, so I got a "bit brutal" with it, and after a bit of "firm" wriggling and twisting, the problem pin retracted sufficiently to allow me to remove the lens. The pin has now been "permanently" retracted so won't cause a problem again
I'm not recommending this procedure as an only solution, but forward it as a possible way out of an otherwise awkward situation.
Good luck
12-29-2018, 02:19 PM   #10
the lens that was stuck was similar to one i had so after 5 hours of wiggling and using a tapemeasure as a quick-key i dismantled the lens
k-mount, kr, lens, pentax lens, slr lens
b4 mount to k mount? video lens on SLR? cadmus Pentax SLR Lens Discussion 6 04-23-2011 06:21 PM
K lens on a KR mount Kambei77 Troubleshooting and Beginner Help 4 12-29-2010 11:25 PM
Lens mount can use with Pentax mount espanola Pentax SLR Lens Discussion 13 02-24-2010 04:48 PM
Is it possible to mount an old CCTV C mount lens to my k20d? WiseOx Pentax SLR Lens Discussion 2 07-15-2009 03:01 PM
Little help? help me identify possible problem and lens mount. mediaslinky Pentax SLR Lens Discussion 4 08-23-2008 06:32 AM
All times are GMT -7. The time now is 03:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
