Originally posted by SylBer One advantage of the Tamron 90mm over the Pentax 100mm WR is aperture ring. You can use it with old vivitar extension tubes and still maintain the ability to use your camera in Av mode. I don't think one can do that with the new Pentax 100mm WR. Achieving ratios bigger than 1:1with a relative ease of use is really cool. Correct me if I am wrong.
No question it's a lot easier and cheaper to use extension rings with the Tamron (vs the 100WR) because it has an aperture ring. I used to have a set of Vivitar AT-23 tubes which I could use with the 100WR (worked quite well actually) as they have electrical contacts that allow you to control the aperture from the body. They're expensive ($150-200) where as you can use just about an extension tube with a lens like the Tamron due to the fact that is has an aperture ring to control the aperture directly.
That said, and someone can correct me if I'm wrong, but I think you'd need quite a bit of length on your tubes (and light) to really increase the magnification of either of these 1:1 lenses much beyond 1:1.
