06-09-2011, 01:57 AM   #1
hcc's Avatar
DA*300mm f4 at Photozone.de
The DA*300mm f4 was tested at Photozone.de with the K-5: "A quite obvious choice for both enthusiasts as well as professional photographers in Pentax land. "
Pentax SMC DA* 300mm f/4 ED [IF] SDM - Review / Test Report
06-09-2011, 02:57 AM   #2
Perhaps even more impressive than the lens is the nerve of that little croc on top of the big one!
http://photozone.smugmug.com/photos/1327985074_gSkkchr-O.jpg
06-09-2011, 03:28 AM   #3
aurele's Avatar
QuoteOriginally posted by DSims Quote
http://photozone.smugmug.com/photos/..._gSkkchr-O.jpg
WOW ! Very impressive, and excellent photo !
06-09-2011, 07:12 AM   #4
Performance looks a lot better than Nikkor 300/4. Why doesn't it score better in their star chart?
06-09-2011, 07:30 AM   #5
QuoteOriginally posted by elho_cid Quote
They always make a point of saying that test results cannot be compared outside of each manufacturer's test group.
06-09-2011, 07:37 AM   #6
A decent review. I completely agree with their findings on build quality. It's really well constructed and has a full metal barrel, making it one of my favorite lenses. The resolution figures seem a little questionable, but I assume the values they calculated depend on the distance from the subject? Anyways, this lens is strong optically and has very low aberrations.
06-09-2011, 07:49 AM   #7
Eruditass's Avatar
QuoteOriginally posted by deadwolfbones Quote
I always interpreted that as the actual resolution numbers and not star ratings.
But for fun, if you look do want to compare resolution numbers, the Nikkor 300mm passes their 86% line for center resolution, and the performance is overall better at f8 than the Pentax at any setting. Of course, border/edges and wide-open is a different story, but the end optical rating is always a subjective ranking of priorities.
06-09-2011, 07:52 AM   #8
RonHendriks1966's Avatar
Only for same sensors there can be a comparison. So if they use the D7000 for testing then comparison gets a new option. But then again what to win or why?
When I look at the test with the 60-250 it is a clearly comparable result with maybe a little notch advantage on CA. Good lens, but we already know that.
06-09-2011, 11:59 AM   #9
Blue's Avatar
In bodies with the same sensor, i.e. the K10d with the sony ccd, rough comparisons can be made. However, with the new CMOS, only comparisons to the D7000 could be roughly made. Furthermore, Photozone needs to also point out to people that it isn't a matter of comparing systems, but that the K-5 and K10d are different ball games as well.
06-09-2011, 09:26 PM   #10
ogl
ogl's Avatar
Not bad. But I'd like to see better resolution at K-5..
06-09-2011, 09:59 PM   #11
QuoteOriginally posted by ogl Quote
No bad. But I'd like to see better resolution at K-5..
It's still an improvement vs. FA* 300 f/4.5 on K10D. Expect very similar results from the Canon and Nikon equivalents on higher pixel-pitch cameras, in future reviews.
06-10-2011, 12:55 AM   #12
gazonk's Avatar
Very nice indeed! But the 60-250 is also a very good lens, and given that the 60-250 isn't that more expensive (and they're similar in bulk), I wonder if the extra 50mm is worth the loss of zoom flexibility?
06-10-2011, 05:38 PM   #13
QuoteOriginally posted by gazonk Quote
It is probably pretty much a toss up between those two lenses for many factors. The DA* 300 does have that extra reach as you mentioned, and I'd also wager the weather resistance is better because it doesn't have any external moving parts. Plus the lens has an all metal barrel. It's probably the highest quality lens from a construction aspect that Pentax currently offers (along with the DA* 200mm).
06-29-2011, 10:41 AM   #14
Je ne connais pas à quoi correspondent ces mesures de résolution mais en terme de piqué c'est le meilleur objectif que je possède. Il est même meilleur que le sigma 120-300 f2.8, en tout cas c'est mon avis.
De plus sa construction est très robuste : je l'ai fait tomber sur un rocher et tout fonctionne encore très bien.
06-29-2011, 11:18 AM   #15
GeneV's Avatar
Is everyone at Photozone named Klaus?
Nice test. It is amazing how many times I've wanted that extra stop with the 55-300 racked all the way out.
da*300mm, da*300mm f4, f4, k-mount, pentax, pentax lens, photozone.de, slr lens
K5 and photozone bluekorn Troubleshooting and Beginner Help 5 02-02-2011 02:15 AM
DA*55 at photozone.de. ogl Pentax SLR Lens Discussion 6 11-24-2009 09:51 AM
DA 15mm at photozone Andi Lo Pentax News and Rumors 33 10-23-2009 02:22 AM
photozone 55-300mm f/5.8 review jms698 Pentax News and Rumors 3 09-30-2008 09:58 PM
New Photozone Review of Sigma AF 100-300mm f/4 APO EX DG Tbear Pentax SLR Lens Discussion 2 02-13-2008 12:53 PM
All times are GMT -7. The time now is 07:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
