06-10-2011, 03:24 PM   #16
psychdoc's Avatar
I have shot stuff on-stage with a 50-135 pentax.
It is plenty long if you can get to shoot from an appropriate distance.
What I also found is that sometimes you really want to shoot at the shorter end to give the shot some atmosphere and not make everything too much like a portrait. Unless you are some kind of professional it is also good to carry something more discreet than a 70-200
06-10-2011, 11:21 PM   #17
It honestly depends on where you are in the audience. So a zoom lens will give you more flexibility. 50-135 will make a good one as long as you can get relatively close to the performers.
Here are some photos I took at a concert with a DA 70mm Limited.
pilgrimage to Portland - a set on Flickr
06-11-2011, 12:15 AM   #18
mikeSF's Avatar
i agree w/psychodoc that you want to cover the "portrait" range of solo performers with your 50-200 range but don't forget to get entire band shots from the edge of the stage using your 16mm or even a fisheye, etc... The lens distortion effect of being close and looking up at a towering performer can be a very cool effect, especially when you can compose it with some stage light bokeh or other context.
I've had success with the 16-45 and 70-200 covering the entire event, even backstage antics. If i have time for primes, i'll throw on a 50mm or 105mm Tak for more artistic looking rendering, but the two zooms can really handle it all.
06-11-2011, 06:16 PM   #19
Marc Sabatella's Avatar
As people say, it depends on where you will be shooting from, and also whether you plan to mostly take closeups or group shots. I take more closeups, and try to be as close as possible. In which case, the 50-135 is the perfect lens assuming you're OK with its cost and with its size/weight. Me, I shoot mostly with my M120/2.8 and DA70. See also my article on equipment for concert photography, in which I mention a 100mm prime as my favorite single lens if I were to be limited to one (and wasn't going to go for the 50-135).
Marc Sabatella: Concert Photography - Equipment
A recent M120/2.8 shot:
DA70:
Plus I always have my DA15 for a wide shot or two:
01-16-2014, 10:43 AM   #20
Hate this. up in the face of every band member and not caring about the people behind them. so annoying.
PENTAX K-01  Photo
01-16-2014, 11:59 AM   #21
Driline's Avatar
QuoteOriginally posted by rzarector Quote
That photo looks rather grainy.
01-16-2014, 12:55 PM   #22
QuoteOriginally posted by Driline Quote
Didn't really play with it too much. Hit AUTO on LR. Didn't make the cut and shot at 3200 on a k-01. BATHED in Red LED light. SO yeah....def grainy and crappy. But thanks for pointing it out! ;-)
01-17-2014, 02:58 PM   #23
Wired's Avatar
Every room is different, which makes it brutal to predict what your going to need..the 50-135mm though is always a safe bet. But I keep the 77mm f1.8 FA Limited in my pocket at all times.
However, the kit lens works nicely too:
DA*16-50 f2.8 is always a good one to have on hand.
I don't like to push the iso too high, 800-1600 is usually where I sit. But the DA*16-50 and 50-135 are staples and I don't think you could go wrong with either. A lot of the rooms I shoot in are more intimate so I usually only need the DA*16-50, FA 43 and FA 77. I only keep the FA 43 on me because of the extra stop of light can make all the difference.
I know there is movement in all of these, but I shoot metal and hard rock bands, they move a lot and I like to capture that energy.
01-17-2014, 03:42 PM   #24
DA* 16-50mm and DA* 50-135mm
01-17-2014, 03:49 PM   #25
Moderator PEG Judges
Kerrowdown's Avatar
IMHO you need good fast glass, medium to long focal length and remember normally flash is not permitted so your at high ISO's, good luck.
01-18-2014, 07:53 AM - 1 Like   #26
sterretje's Avatar
I hope geoles2 is not waiting for an answer after two-and-a-half year
01-19-2014, 10:29 AM   #27
Lol @sterretje I have it figured out, pretty much Ha.....
k-mount, lens, lens for concert, pentax lens, slr lens
People Experimental Concert Photography kevinschoenmakers Post Your Photos! 2 05-17-2010 07:04 AM
Available Light Concert Photography Richter Welcomes and Introductions 3 04-28-2010 10:59 AM
People Concert Photography - my first go mikeSF Post Your Photos! 14 01-22-2010 09:11 PM
Fast Lens telephoto for low light concert photography? superfuzzy Pentax SLR Lens Discussion 49 12-02-2009 12:24 AM
concert photography rwheeler Photographic Technique 6 10-05-2009 09:38 PM
All times are GMT -7. The time now is 11:08 AM. | See also: NikonForums.com, part of our network of photo forums!
