06-11-2011, 12:10 PM   #1
Focusing Help
Hi everybody, I have a kx with an asahi 1.7 manual lens, it takes great pics, as long as I can get them in focus .
Any tips on camera set up, focusing tips, seems like i am not always getting things in focus, blurry etc? Is it just practice?
Thanks, George
06-11-2011, 05:45 PM   #2
A couple of things come to mind. Are you trying to take a lot of pictures at f1.7? If so the depth of field is not paper thin, but not as thick as you may need. Take a look at this link.
You might try stopping down to say f5.6 to f8. Depending on the light your shutter speed may slow down, so increase you ISO to compensate. The Kx has a lot of room in terms of ISO speed. Stopping down also has the byproduct of increasing the image's resolution (up to a point - f8 is usually the sweep spot).
If your shutter speed is too slow, you may induce some blurriness. Is SR on? and how slow is your shutter? Are these indoor or outside?
Then there is the viewfinder. Modern day viewfinders are not really designed for manual focusing. My old Spotmatic has a wonderful split screen viewfinder. You can swap this out, but you may encounter problems with the spot metering, with something like the katzeye. One solution here is the above suggestion - fatten up the depth of field.
Technique, practice and skill.....
hope that helps...
06-11-2011, 05:54 PM   #3
Marc Sabatella's Avatar
I always say this: the biggest thing to understand is that the viewfinder shows too much DOF when shooting at large aperture (anything from f/1.7 to f/2.8). You can easily test this for yourself by shooting some text at an angle and comparing how many lines *appear* in focus in the viewfinder versus how many are *actually* in focus in the picture. Once you wrap your brain around that, you can begin to work on how to account for that.
focus, k-mount, pentax lens, slr lens, tips
K7 focusing issues. aragondina Troubleshooting and Beginner Help 8 05-26-2011 10:12 AM
K-x back focusing A-z Troubleshooting and Beginner Help 17 05-23-2011 05:25 PM
odd issue with focusing olaf ibsen Troubleshooting and Beginner Help 7 04-03-2011 12:22 PM
Need Help! Sigma front focusing. driftingbunnies Pentax SLR Lens Discussion 6 12-10-2010 01:14 AM
Does this DA* 60-250mm have questionable focusing? Clinton Pentax SLR Lens Discussion 2 07-12-2010 06:31 PM
All times are GMT -7. The time now is 08:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
