Originally posted by raymeedc I am presently, & have always been, owned by cats, the present configuration consisting of two longhaired Main Coons. The occasional pass under running water seems to circumvent most problems not solved with a simple blast of air/brush (the hood, not the cats).
P.S. - When not in use, I keep my equipment in dust free sealed cases.
How do you usually use the filter when you are using the hood, do you fix the filter to the lens thread and in the filter thread you attach the hood?
All DA35mm users, please suggest me a best combination of filter(ND and polarizer) and hood solution for this lens please. Any links to online shops will be much appreciated!
Let me know your opinion on
this please.
Also, suggest me some good cokin solution and suggest me which one is good to go with. Cokin or the more traditional one considering my filter and hood usage.
thanks
