06-12-2011, 12:19 AM   #1
lens question -- HELP!!!
my longest lens is the 55-300 but i want more reach without braking the bank. i'm thinking of the da 300mm with a tc but what about clarity?? can someone post some pics please and/or offer more suggestions. thanks !!
06-12-2011, 12:31 AM   #2
twitch's Avatar
You mean the DA*300 + TC? If so a bigma (Sigma 50-500) is probably cheaper
06-12-2011, 01:17 AM   #3
I think you will find that, if buying new, the DA*300 can be a bit on the expensive side. Then adding a TC would add to that expense. And remember it is an SDM lens,so buying used could have some risks involved.
(SDM reported to be a bit unreliable in some cases.)
Anyway I have the lens and am very pleased with its capability. Up to this time I have found the length to be sufficient for me without having to add a TC.
Last edited by Bramela; 06-12-2011 at 01:08 PM. Reason: Not accepted as a good sample, maybe justifiably.
06-12-2011, 03:38 AM   #4
QuoteOriginally posted by Bramela Quote
Sample as requested.
It looks over-sharpened and cartoony.
...in any event, I really like the DA* 300 f/4, but I've never used it with a TC. A TC will degrade image quality and slow your lens down. Cropping will degrade image quality, but will not slow the lens down. Pick your poison.
06-12-2011, 04:06 AM   #5
Coeurdechene's Avatar
QuoteOriginally posted by kat1351 Quote
Depends on how serious you are about the extra reach and it's usage...
If you want something long and cheap you can look for a SP tamron 500 mm. it's a mirror lens but has a good rep, it's been called one of the few decent IQ mirror lenses...
You can also look for a Tamron 300 f2,8 and a TC..but that will probably be much more expensive.
If you are real serious about it just save the money for a good lens (probably bank account drying one)...you'll end up buying one so just cut the middle steps.
06-12-2011, 06:54 AM   #6
testdasi's Avatar
Sigma 50-500 / 150-500 will cost less than DA* 300 + TC.
06-12-2011, 07:57 AM   #7
RioRico's Avatar
I'll sell you my Lil'Bigma 170/500 for US$650, like new, complete package.
That's because I don't use it, preferring my much lighter/smaller 500/8 mirror.
06-12-2011, 09:20 AM   #8
What is your budget? The Promaster 1.7x TC auto focuses the 55-300mm fine in daylight on my K-R. The IQ seems a little better to me, than cropping for the same size, but not much. The Tokina 500mm f/8 (or Sears brand) is pretty sharp far a mirror lens, but lacks contrast. The high IQ options will cost very much more, as others have said.
06-12-2011, 01:18 PM   #9
Due to the critique on my other photo,probably justified, which I have deleted, I will add another.
This is from the camera. Do not be mislead. The colour of the Lorikeet can be rather saturating.
06-12-2011, 02:56 PM   #10
Let me do a bit of research & I'll get back to you.
K
06-12-2011, 03:15 PM   #11
The Tamron 500mm mirror lens is decent if you can increase micro-contrast in post-production, find f8 fast enough, and do not mind doughnut-shaped bokeh. It is inexpensive, light, and much easier to hand-hold than a standard long telephoto. With the Tamron 2x you get 1000mm f16.
06-12-2011, 06:12 PM   #12
I was not critical of the other though I felt somewhat the same way. This one is smashing! A really good capture.
06-14-2011, 10:31 AM   #13
hey RioRico,
after much consideration, my choice is the Sigma 50-500 or the DA*300mm.
06-14-2011, 11:08 AM   #14
hey RioRico,
Sigma 50-500:
Sigma Lens: Zooms - Sigma 50-500mm f/4-6.3 EX DG HSM APO (Tested) - SLRgear.com!
BTW, there are two versions of the 50-500 (OS and non-OS). AFAIK, the newer one is actually slower through most of its range.
k-mount, lens, lens question, pentax lens, slr lens
lens question - manual lens won't fire wackymummy Troubleshooting and Beginner Help 7 05-21-2010 10:16 AM
New Kx and lens question. Myltlpny Pentax SLR Lens Discussion 5 03-14-2010 08:47 AM
lens question? LosHollyBeach Pentax SLR Lens Discussion 3 02-01-2010 11:43 PM
Help with Lens question regarding IQ joodiespost Pentax SLR Lens Discussion 16 01-01-2010 09:31 PM
New FA 31 lens question Mr Toad Pentax SLR Lens Discussion 9 10-05-2009 11:13 PM
All times are GMT -7. The time now is 06:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
