I second the rubber collapsable lens hood suggestion. I bought my first one a year ago for the DA 55-300 zoom. At first I kept switching back and forth between the rubber hood and the stock plastic hood that came with the lens because of feeling like I might be doing a disservice to the lens somehow by using a cheap rubber hood. But after a few months of that silliness I found out a lot of positive things about using a rubber hood.
Many rubber hoods, such as most of
these found on Ebay, extend into three different lengths, so you can choose what works for your lens (though for very wide lenses look for a hood designed for that). They are lighter than any plastic or metal hood, and after collapsed are more compact.
Some additional benefits I've discovered is that they serve as a cushion for the lens, and the rubber around the lens helps secure the lenses in lens compartments in a camera bag. Also, if you make sure the rubber hood has threads that accept a filter in the front, you can use step up/down adapters to get by with one set of polarizing and ND filters, as I detailed
here.
My lenses with rubber lens hoods:
