11-11-2007, 03:08 PM   #1
Tripod socket for Bigma
I have loosen off the clamp.
When I wish to turn the lens from veritcal to Horizontal, the lens either sticks or is difficult to turn.
Is there something I can either spray or wipe on the inside of the socket, to allow the lens to turn easly.
Thanks
11-11-2007, 03:19 PM   #2
Moderator Emeritus
I'm not sure what the issue is. I just tested mine and if i loosen the collar and then turn the collar 90 degrees then tighten it down the lens acts normally. Focus and zoom rings are the same in both positions. Did you move the collar forward a bit and tighten it too much? Maybe causing the lens to bind up a little? If it works in portrait mode it should be the same in landscape.
I wouldn't lubricate anything on the lens as it could get inside on the glass or aperture and you would be faced with an expensive cleaning. Try it again and make sure the marks are lined up straight before you tighten the collar and don't over tighten it.
11-11-2007, 04:02 PM   #3
Remove the socket completely. There is a notch that will allow it to come off the lens. Once that is done, inspect both the lens and the tripod collar.
I would not lubricate it at all for the same reasons the previous poster mentioned. It should fit snugly but freely.
11-11-2007, 05:34 PM   #4
If absolutely necessary take the tripod socket right off and away from the lens.
Then apply a small amount of car wax to the socket it's self.
Then buff it off like on the directions.
This might allow everything to slide a little bit better, and shouldn't hurt the lens.
k-mount, lens, pentax lens, slr lens, socket, tripod socket
x socket problem vamountainman Pentax DSLR Discussion 2 03-10-2010 04:27 PM
K20d's PC Socket Cap SirGMT Pentax DSLR Discussion 1 11-12-2009 09:53 AM
Small Bigma Tripod Collar and Tripod Mount ? wll Pentax SLR Lens Discussion 0 07-25-2009 08:46 AM
PC sync socket on K20D Anya Troubleshooting and Beginner Help 6 05-15-2009 08:28 PM
does K20D use screwlock PC socket? kenyee Pentax DSLR Discussion 4 11-15-2008 09:32 AM
All times are GMT -7. The time now is 10:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
