Originally posted by RioRico @OP,
If your lens is also marked KR with an A(P) aperture setting, it is indeed a Ricoh/Pentax mount. That protruding lever is the aperture stop-down flag. It has NOTHING to do with any shutter! You should be able to set the aperture to something like f/11, then push that flag, and the iris should close down. Some KR lenses do have the bad Ricoh pin, but that flag isn't it, and none of my Sears KR lenses contain it.
The third-party (such as Sears) lenses for Konika cams that I have seen are marked KAR or K/AR, not KR. Note that Sears marketed lenses from many lensmakers (including Pentax) and multiple versions of the 135/2.8 exist -- I have had 4 different versions for Pentax, each with slightly different mounts. Is that flag (pin) round or flattened? If it's indeed round, then it is most likely NOT for Pentax.
Clearer pictures would really help.
Ok... aperture stop-down level...cool.... It is round and it still doesn't do anything when push. The iris doesn't close down, also turning the aperture ring (f/22 to f/2.8) doesn't open or close the iris either.
After looking over the lens I can't find an marking that say KR, KAR, or anything. So I am guessing it's not a Pentax lens.
Did you happen to see the 2nd picture I posted? It's a clearing shot.
Thanks for your help
