06-15-2011, 07:14 AM   #16
Docrwm's Avatar
QuoteOriginally posted by Northern Soul Quote
True - hence the 85mm f2.2 soft lens
That said, if you start with a sharp image you can always soften in in PP. You can't do much to sharpen a soft image though, so I'd lean towards getting the sharpest starting image.
True, I'm still getting used to the switch to digital........softening is easy in PP and sharpening can make pictures look sort of cartoonish.
06-15-2011, 08:00 AM - 1 Like   #17
Kennod's Avatar
QuoteOriginally posted by sany Quote
Thanks All!
My original intention for starting the thread was to find out stopping the f1.x lens to f2.x readings will it still retain its title as a fast lens and for low light if not can the same job be done by lens with max aperture at f2.x.
Hi Sany,
there is one general advantage of an f1.x lens stopped down to f2.x, compared to a lens of the same focal length with maximum aperture of f2.x. The image quality of most lenses improves significantly when stopped down 1 or 2 stops from maximum. So the image quality from a 50mm/f1.4 stopped down to f2.0 may be better (sharper, less vignetting etc) than a 50mm/f2.0 wide open.
Also, in extremely low light you still have the option of shooting wide open. The lens may not produce it's sharpest images, but at least you can get the shot!
Personally, for portraits I use either 85/1.4, 50/1.7 or 77/1.8 and stop down to f2.0.
This generally provides sufficient centre sharpness (particularly on the eyes) but still very shallow DOF and nice background bokeh.
Of course this is all matter of personal preference. There are plenty of f2.4 and 2.8 lenses that can produce beautiful portraits. A fast f stop is just one factor.
Have fun!
06-15-2011, 09:23 PM   #18
Marc Sabatella's Avatar
I find my 18-55 kit too long at 55mm in my house unless it's just head and shoulders
Well yes, but, that's kind of the short working definition of "portrait", is it not? Obviously 70mm isn't a good general purpose lens on APS-C, but for portraits specifically, I think the bathrooms are the only rooms in my house that are too small for a portrait at 70mm.
focus, k-mount, lens, lenses, light, pentax lens, portrait, portraits, slr lens
Fast Low light lens for Indoor shots with K100D Mathew J Pentax DSLR Discussion 13 06-18-2011 07:20 AM
What's a good, cheap lens for indoor, low light situations? mojoe_24 Pentax DSLR Discussion 31 01-19-2011 12:02 AM
Best lens for indoor kids portraits in low light gbandi Troubleshooting and Beginner Help 24 03-06-2010 04:13 PM
Lens Recommendation (prime) - Bokeh, Indoor, Low Light FckShoes Pentax SLR Lens Discussion 16 12-02-2008 08:06 PM
Whats a good indoor/low light photo lens? Jewelz Pentax SLR Lens Discussion 12 11-25-2008 02:46 PM
All times are GMT -7. The time now is 10:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
