06-16-2011, 02:56 PM   #1
TTL turn off
It seems that I can't turn off the TTL flash on the built in flash of my K-X, no matter what mode I'm in.
If anyone knows a way to bypass the pre-flash, I would greatly appreciate it!
Jake
06-16-2011, 03:23 PM   #2
enoeske's Avatar
the pop up flash is p-ttl only unless you are using a pre-a lens in which case it fires full power every time
06-16-2011, 03:28 PM   #3
DAZ
DAZ's Avatar
If you us a older, none "A" mode lens the camera will flash but only with full power. You will have to adjust your aperture to get the correct setting. This is one of the biggest limitations with the built in flash on the Pentax cameras. No way to have the flash work in manual mode, other then the full power with an older lens.
DAZ
06-16-2011, 03:45 PM   #4
QuoteOriginally posted by FrumPilot Quote
Jake
Jake, what are you trying to do?
What's been said so far is true and there are a few ways to proceed depending on what you want to do & what kind of lens you want to do it with..
One way is to cover all the camera mount pins with aluminum foil before mounting the lens. The flash will think a non-A type lens is mounted and fire at full power; but you might not be able to adjust the lens depending on what type it is.
06-17-2011, 06:14 AM   #5
Hi and thanks for the feedback. The reason why I wanted to have the onboard flash witout ttl is that I bought an umbrella and have 2 flashes with slaves, I wanted to trigger them via the onboard flash, albeit at a lower power setting.
This did not work because of the TTL's preflash. Interestingly the preflash did not trigger my friends Nikon flash with the same optical slave. I might just have to get a cheap flash just to trigger them (or a radio trigger) but I really did not want to spend more money on this! Oh and I'm using mainly a 35-70 F lens, and I do not want to fool arounf=d with the pins on the camera. I feel it's too risky.
Thanks again!
Jake
06-17-2011, 06:31 AM   #6
Lowell Goudge's Avatar
Thanks again!
Jake
You really need to consider a small flash, or since you are probably doing a manual set-up any way, take the F lens out of the A position, this will then use the internal flash which is about 16GN (100ISO in meters) at full power, but in sync with the shutter and no preflash.
I am not sure whether the 16GN is too broght at full power for your use however.
you could always place a difuser in front of it.
06-17-2011, 06:44 AM   #7
GeneV's Avatar
Some radio triggers would really be the cheapest and simplest solution. There are also optical slave triggers that can be set to ignore the preflash, but that takes some tinkering with the settings. I've only found the on board flash particularly handy for triggering other P-TTL flashes.
06-17-2011, 05:15 PM   #8
DAZ
DAZ's Avatar
If you really donít have the money now you could give a little DIY a try. I used this before I got radio triggers and they are better but this is free. Get the camera to use full power by using a lens in a non A mode. Set your f-stop that you are going to use and pop up the flash. Put something (some aluminum foil or a piece of paper so that the center of the flash is blocked. You will have to play a little with it so that your slave will fire but not get to much light on your subject from the camera flash. Radio triggers are better but this is cheap and you can do it now.
DAZ
flash, k-mount, pentax lens, slr lens, ttl
Difference between TTL and P-TTL flash. rod_grant Pentax DSLR Discussion 35 12-25-2012 06:42 AM
Pentax 67 TTL Prism Problem dellos Pentax Medium Format 3 02-08-2011 05:02 AM
Pentax 540af P-TTL issues imfinetoday Pentax Camera and Field Accessories 2 08-23-2010 11:36 AM
Is there a way I can turn p-TTL off or manually override it in a mode other than M? ismaelg Pentax DSLR Discussion 10 04-15-2010 10:51 AM
To turn right or to turn left spura Pentax SLR Lens Discussion 14 04-15-2009 11:29 AM
All times are GMT -7. The time now is 05:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
