Originally posted by grinchicago but turns out I had to do it a couple of time before it actually registered,
It should not need to set couple of time, once should be enough on a K-x. And it should be that way until you change it to something else or reset the coustom setting (no mater you turn it of or remove battery for short time)
Originally posted by photolady You'll need to set it every time. Same as my K-x. It's annoying but at least we can still use m lenses.
And for the focal length, yes it will ask but you don't have press ok as long as you are using the same lens, just pressing the shutter after turning the camera on, will take you to the normal screen. You might notice, K-x actually remembers the last used focal length, i.e. for same lens mounted on (just to be clear K-x do not remember the lens just the FL number you selected), every time you turn off and turn the camera back on focal length screen shows the previous fl on the middle already highlighted. At that point I don't even look at it any more, I just half prees the shutter.
