I don't know what it is, but here's my opinion.
If it's a Zoom leave it alone. Otherwise you'll never get it back together and working properly.
If it's a prime then you have a chance of fixing it yourself.
The lenses that I've played with require you starting at the top, by removing a ring threaded into the filter threads.
to give you an idea what I mean by ring it'll often but not always have that writing on it with the size and what not.
Try using an eraser to grip this ring, although I've had to use a tiny screwdriver on some.
Be careful with the screwdriver, you don't want to scratch the glass.
I wouldn't worry about scratching the ring unless you plan on selling the lens sometime.
After you get that ring off it'll make a little more sense of what needs doing next.
You will need a couple of Jewelers screwdrivers for this job.
I should mention that you might be better off just buying another one through
KEH Camera.
I'll only buy lenses in excellent shape through them, but they're often worth it.
Have fun, and good luck with it.
Plus your not alone, I have to take 2 lenses apart soon for a little cleaning or repairs.
