06-18-2011, 10:12 AM   #1
Senior Moderator
Nass's Avatar
Looking for specific type of lens, plz help
Hello,
Quick q. For you lens experts out there - I'm trying to identify a cheap and nasty lens to purchase in order to take the glass out and use it for a pet project of mine. Specifically, any k mount lens which is about 5-10 cm long, but extends to 15 to 20 cm. I'm looking at a macro I think - any suggestions?
Thanks!
06-18-2011, 10:44 AM   #2
I think you'll have a hard time finding what you want. The old macro-takumar 50:4 1:1 lens has a double helicod with a lot of extension - 50mm total.
Any non-IF 1:1 macro lens will have an extension equal to its focal length.
Good luck finding one. Can you use a Bellows?
06-18-2011, 11:36 AM   #3
Senior Moderator
Nass's Avatar
Thanks newarts - yes, it's actually to replace a bellows - I'm making it into a variable length extension tube. I've got an m50 macro which will do what I want but I don't really want to destroy it, was hoping for some cheap and cheerful alternative =)
06-18-2011, 11:43 AM   #4
QuoteOriginally posted by Nass Quote
Helicoid extension tubes were made & if you are lucky you might find a few. If you are even luckier you might be able to afford them.
Die Cast Pro - Asahi Pentax Helicoid Extension Tube
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=helicoid...All-Categories
Your best bet might be to place a "wanted" ad here for a junk 1:1 macro lens & use its helicoid.
06-18-2011, 11:46 AM   #5
RonHendriks1966's Avatar
Isn't it easier to find a bellows?
foto-tip - photo accessories
06-18-2011, 11:51 AM   #6
Senior Moderator
Nass's Avatar
Those are neat =). You're right, that's probably the best route, scouring ebay's "lenses for parts" gets a bit boring. Ron, thanks but no I specifically don't want bellows.
06-18-2011, 11:52 AM   #7
Senior Moderator
Nass's Avatar
Amazing what Pentax used to make back in the day =)
06-18-2011, 11:59 AM   #8
It may be practical to inexpensively fabricate an adjustable nested-tube based rigid extension tube from appropriate cheap extension tube ends and nesting tubes. It wouldn't be pretty most likely.
1-3/4" ID and 1-3/4" OD tubes are standard machine shop items.
06-18-2011, 12:26 PM   #9
RioRico's Avatar
Some 35mm-slide projector lenses are built with loose large-helicoid tubes. I have a GoldE 5-inch f/3.5 Anastigmat whose tube is 5.5cm, extending to 10cm. I mount this on cheap PK macro tubes via a thick-flange M42-PK adapter. Glass/tube inner diameter is 3cm+. If I had a bad copy of this (but mine is good!) and knocked out the glass and used a full 5cm set of tubes, it would exactly meet your specs.
Thus: Look for old projector lenses. My costs: lens, US$2.25 shipped; M42-PK ring, US$3.50; PK tubes, US$7. Such a deal!
06-18-2011, 12:35 PM   #10
Good idea as usual from this poster!
06-18-2011, 12:35 PM   #11
Senior Moderator
Nass's Avatar
Epic - exactly the sort of things I'm after. Thanks gents =)
06-18-2011, 03:29 PM   #12
Lowell Goudge's Avatar
there are some commercially available focusing helixes.\
I have one for my M42 set, whihc really acts lime a 15-30mm expandable extension tube.
there is also the vivitar macro-focusing 2x teleconverter, that has a 50mm extension capability built in so that it gives 1:1 with a normal - non macro 50mm lens
k-mount, lens, pentax lens, slr lens
What type of lens is this? yusuf Pentax SLR Lens Discussion 4 10-31-2010 07:04 AM
Newbie - need help with Lens selection, specific use nboard10 Pentax SLR Lens Discussion 23 03-28-2010 06:58 PM
Info Plz on a Komine Made Vivitar Lens geezer52 Pentax SLR Lens Discussion 5 02-12-2010 10:24 AM
specific question about kit lens II vs. DA 16-45mm causey Pentax SLR Lens Discussion 4 11-03-2009 11:05 AM
Help plz. widest pentax lens with lowest distortion? kiamon Pentax SLR Lens Discussion 14 06-02-2008 05:41 PM
All times are GMT -7. The time now is 06:27 PM. | See also: NikonForums.com, part of our network of photo forums!
