06-20-2011, 10:25 AM   #1
AMBIVALENCE's Avatar
DA* Focus Ring 50-135 Problem
Hi Guys!
I don't know if anyone have had ever experience such weird problem.
I have recently bought a DA* 50-135 2.8 from a member here and it worked fine for a day, then the next day I tries to use the lens, the focusing ring doesn't want to focus - BOTH Auto and Manual focus does not work. It gets stuck close to the infinity side.
What I am saying is that when you tries turn the ring it will turn but the focus does not change. It may seem like the gear has detached, but then it works if you rock the ring back and fourth slowly.
There is definitely no sand or anything stuck in between, because the ring turn as smooth as butter. I also have not put it through the test of weather, so it's good! It also doesn't seem to be like the SDM motor problem, because i have never heard that the MF will also fail, usually the lens will still work manually, right?
I contacted the seller, he said he had never drop the lens (tho with scratch mark), and the parcel i receive seems to be a good condition so I don't want to accuse him with anything. But can someone point me at the right direction on what I should do in such situation/or what the problem actually is?
PLEASE HELP! Thanks!
PENTAX K-x  Photo
06-20-2011, 10:40 AM   #2
GLXLR's Avatar
Send it in for repair (CRIS cam will fix it free if still under warranty). Probably focusing clutch is getting stuck at infinity.
http://www.criscam.com/third_party_logistics_pentax.php
06-21-2011, 09:25 PM   #3
this is what I am trying to find out from the seller, he said he lost the recipt. What should I do ='(
let say its a clutch problem, how much approx would that cost to fix?
da*, day, focus, k-mount, lens, pentax lens, slr lens
Focus Ring on DA 35 macro makes a clicking noise; manual focus ... this normal? eadrian75 Pentax SLR Lens Discussion 2 04-12-2011 12:51 AM
Focus Ring? NecroticSoldier Troubleshooting and Beginner Help 6 04-26-2010 12:50 PM
DA` 50-135 focus problem calicojack Pentax SLR Lens Discussion 15 11-16-2008 02:39 PM
K20D+DA*50-135 focus ring problem. Steven Yampolsky Pentax DSLR Discussion 4 04-15-2008 06:36 AM
DA` 50-135 focus problem??? calicojack Pentax SLR Lens Discussion 6 03-03-2008 02:46 AM
All times are GMT -7. The time now is 02:02 AM. | See also: NikonForums.com, part of our network of photo forums!
