11-14-2007, 05:59 PM   #1
Old screw mounts.
Hi,
I have a K10D and I am wondering if there is an adaptor that converts my mount to a screw mount?
I have two old lenses from back in the 70s. A 35mm 2.1 and a 135mm 2.8.
I forgot I even had that old SLR and lenses. Not Pentax brand but may be pentax screw mounts.
11-14-2007, 06:35 PM   #2
Moderator Emeritus
Yes there are a couple of adapters that you can get on Ebay and a few other places like KEH and B&H. One has a collar with a locking slot on it. That is easier to remove but you can't focus the lens to infinity. The other that comes from Pentax and a few aftermarket places has no collar. A little harder to remove but the lens will work normally. With this one you put the adapter on the camera and then screw the lens in.
With collar:
M42 Pentax, Zenit Lens to Canon EOS Mount Adapter Ring - (eBay item 290178271962 end time Nov-15-07 01:07:01 PST)
Without collar:
NEW Pentax Screw Mount M42 Lens to PK K Camera Adapter - (eBay item 180179498541 end time Nov-15-07 04:00:00 PST)
11-14-2007, 07:00 PM   #3
Peter,
Thank you very much!!!
11-14-2007, 07:42 PM   #4
I just got one from Gadget Infinity, M42 Lens Adapter Ring for Pentax K110D K100D K10D - (eBay item 170167973672 end time Nov-17-07 10:55:49 PST), its a clone of the Pentax adapter, works just as good, is cheap, and does not require a tool for removal.
11-14-2007, 07:43 PM   #5
Fritz's Avatar
But don't buy the first one that Peter linked to, because that one is for a Cannon EOS! Make sure you get one for a Pentax k mount.
Many on this site highly recommend the Pentax brand one. I'm using a Bower branded one, and it works fine.
When you get the adapter, here is a link that will help you use the lenses correctly with your camera.
https://www.pentaxforums.com/forums/pentax-photography-knowledge-base/3800-ca...unt-d-slr.html
11-14-2007, 08:42 PM   #6
Stratman's Avatar
you can also get them directly from pentax !! PentaxWebstore Mount Adapter B (35mm Screwmount to Bayonet)
11-14-2007, 09:38 PM   #7
Mine is Pentax brand, and I highly recommend it
It hardly ever makes it off my camera now
11-15-2007, 04:42 AM   #8
QuoteOriginally posted by Stratman Quote
I believe this is the opposite of what I need.
11-15-2007, 04:50 AM   #9
Moderator Emeritus
Nope that is excatly what you need. It has the bayonet mount for the camera and the screw mount for the old lens. I only wish they had some sort of reverse version so I could mount my 77mm Limited to my old screwmount bellows....
11-15-2007, 05:20 AM   #10
JCSullivan's Avatar
QuoteOriginally posted by Peter Zack Quote
If I'm not mistaken it does exist but costs 2 arms and a leg. On the other hand the M42 mount Asahi bellows is quite difficult to mount on any of the D camera because the flash housing jutts out - but still doable.
Question
What would happen if one was to take the clip off the Pentax clone adapter.
11-15-2007, 08:16 AM   #11
Well there ya have it. I spoke before looking.
Yes, that is exactly what I need, however, why are so many things at the Pentax store listed as "out of stock"?
Do they wait until they get a certain number of request before they have them manufactured? If that is the case I could be waiting a very long time.
Thanks again for the help,
Tom
11-15-2007, 09:14 AM   #12
Not Registered
Guest
You can buy them from adorama also (I bought a couple of them recently). http://http://www.adorama.com/CZPUPKA.html?searchinfo=screw%20mount%20to%20b...pter&item_no=1
Hope it helps
Javi
11-15-2007, 09:27 AM   #13
jeffkrol's Avatar
Just use a step down ring on the front and reverse the lens to the bellows. Probably optically better that way anyways....
k-mount, lenses, pentax, pentax lens, screw, slr lens
Old screw mounts from the early 80s on a K20D LordJezo Troubleshooting and Beginner Help 5 11-08-2009 03:35 AM
Any other kinds of screw mounts? Eruditass Pentax SLR Lens Discussion 6 10-26-2009 04:55 PM
Metering Screw-mounts wildboar Pentax SLR Lens Discussion 3 06-21-2009 08:49 AM
NON-SMC Screw-Mounts; Any Good? rdrum76 Pentax SLR Lens Discussion 0 10-29-2008 02:29 PM
Non-SMC Screw-Mounts; Any Good? rdrum76 Pentax SLR Lens Discussion 8 11-17-2007 12:38 AM
All times are GMT -7. The time now is 02:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
