06-22-2011, 01:11 PM   #1
bobva's Avatar
O<----->L
Whats this for?
Vivitar 24mm 2.8 Perfect Pentax M42 Wide-Angle lens | eBay
06-22-2011, 01:20 PM   #2
bobva's Avatar
Also am I suppose to hold(ROLL) the M up will using the aperture?
06-22-2011, 01:30 PM   #3
That lens is a T4 mount lens, with a T4-to-M42 adapter.
Push the latch in, turn the adapter in the "O" direction to remove (open) the adapter, "L" to lock.
For more details, do a search for "T4 mount" or "TX mount."
(TX mount is similar to T4 mount, but can accommodate full aperture metering).
06-22-2011, 02:01 PM   #4
ryan s's Avatar
Yep, the O-L is for the mount. Make sure that little tab is "up" and the lens is locked into the mount
The A-M switch (auto-manual) will be an "instant" switch, either opening or closing the aperture blades. It will need to be towards the M position for the aperture to close.
Some people prefer setting the aperture with the lens on A, focusing, then flicking the switch over to M to meter in Av mode and shoot the picture. Others prefer keeping the lens in M and opening it to max aperture, focus, then count the clicks to move the aperture ring to its desired f/stop.
k-mount, pentax lens, slr lens
All times are GMT -7. The time now is 07:39 AM. | See also: NikonForums.com, part of our network of photo forums!
