06-23-2011, 08:48 AM   #1
Docrwm's Avatar
Problem with M lens and green button
Just got an M200/f4 lens in from a seller on eBay who said it worked fine on his K-x. Glass is clean and clear. Aperture blades are snappy. However, when I mount it on my K-x, set everything to manual, and press the Green button for metering everything goes black and stays that way. It will take pictures in full manual mode, it's just that the metering will not work with this lens. I've got other M lenses and have never had this happen with any of them. Any ideas?
06-23-2011, 08:58 AM   #2
I don't know how to help you, but does it work if you set everything manual without using the green button?
06-23-2011, 08:59 AM   #3
Docrwm's Avatar
QuoteOriginally posted by kenafein Quote
Yes, and I'm getting some very sharp shots once I get the shutter/f/ISO set right.
06-23-2011, 09:02 AM   #4
If the aperture blades are snappy then there shouldn't be a problem. Try using the DOF preview button to meter instead, maybe that'll work
06-23-2011, 09:06 AM   #5
I've tried using the DOF preview method on my K100D. It's no green button, I'm glad I can use AV mode with my super taks.
06-23-2011, 09:13 AM   #6
There's a way to use M lenses in Av as well.
Set the lens to its smallest aperture.
Put the lens on the camera.
Press the lens release button and turn the lens until you see the aperture close all the way.
Set your camera to Av and enjoy.
Just remember that the lens is no longer 'locked' on and be careful not to twist it off. The lens mount is tight enough that it shouldn't happen but of course it could.
06-23-2011, 09:48 AM   #7
Docrwm's Avatar
Tried this and got a nice image to preview. Thanks. Problem is that the lens is now making the mirror lock up and then stutter. Bad, very bad. I think I have figured out why though. Look at this picture. The piece behind the aperture control is broken off!
06-23-2011, 10:14 AM   #8
I hope the guy accepts returns
06-23-2011, 10:46 AM   #9
Docrwm's Avatar
Apparently not...... Technically his description is accurate. The glass is clear, focus is smooth, and aperture is snappy. Of course there is the minor issue of it having been dropped on its mount and snapped off a piece that prevents it from working properly with a K-x......
06-23-2011, 10:56 AM   #10
Then negative feedback is appropriate. Sorry about your lens.
06-23-2011, 11:16 AM   #11
QuoteOriginally posted by JeffJS Quote
My only M series, the 28/2.8, the aperature ring is pretty stiff, it would totally come off. Very interesting tip though! If I come across any other M lenses I will try it.
06-23-2011, 11:20 AM - 2 Likes   #12
Hi
Don't worry about the plastic piece as it has no part in any aperture use.
Looking at the small arm you can see that there is a scratch mark, that is from the camera control arm. Probably what is wrong is that the lens arm is slightly bent so that it does not engage the camera. just bend it a little towards the outside and it should work fine.
Another option is to completely remove the plastic sticking up and bending the arm towards the inside, that way the lens will work as the Taks. in Av mode.
06-23-2011, 11:34 AM   #13
Docrwm's Avatar
QuoteOriginally posted by bobpur Quote
Hi
Thanks for the thoughts. The part that is snapped appears to be metal - is it actually plastic? I do see what you mean about the aperture arm/pin being bent in toward the center of the lens. I'll try to gently bend it so it is more perpendicular to the plane of the mount and see if that resolves this issue.
06-23-2011, 12:54 PM   #14
Docrwm's Avatar
Hi
Looking at the small arm you can see that there is a scratch mark, that is from the camera control arm. Probably what is wrong is that the lens arm is slightly bent so that it does not engage the camera. just bend it a little towards the outside and it should work fine......
Absolutely did the trick! I can use LV and the Green button now with the lens. Thank you very much. I thought the lens was a write-off - glad its not because it seems VERY sharp.
06-23-2011, 01:10 PM   #15
Hi
Awesome advice bobpur +1! I will remember this.
button, k-mount, k-x, lens, pentax lens, slr lens
Green button - who really uses it? jpzk Troubleshooting and Beginner Help 45 01-07-2011 01:59 PM
Green Button Metering with Manual Lens zombieCat Pentax DSLR Discussion 4 02-15-2010 06:07 AM
SR and green button slow2focus Troubleshooting and Beginner Help 7 12-12-2009 11:56 AM
Green button and old lens deudeu Pentax DSLR Discussion 3 04-15-2008 09:43 AM
K10D and Green Button Manual Lens Shutter Speed David Pentax DSLR Discussion 4 10-15-2007 12:41 AM
All times are GMT -7. The time now is 02:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
