Originally posted by luftfluss Thank you for the detailed reply.
I know that there is a bit of luck involved with sample variation; my 1st DA L 18-55 which came with my K2000 was noticeably sharper at the extremes than the DA L 18-55 that came with my K-x.
ok, i went and twisted the FA onto my camera and adjusted the heck out of its microfocus, and used it a bit: i
do have to change my tune.
My new observation is that it's ok for sharpness center frame wide open, lots better stopped down to f8 and below; borders and corners become unobjectionable by f9.
As benhai says:
Originally posted by benhai 1. More vivid colors and more fine color transition details. 2. Longer range. 3. It blurs the background nicer then the kit lens. I normally take kids picture, so the 28-70mm f4 is always on my camera.
Originally posted by benhai The 18-55mm AL feels stronger. Colors that the kit lens renders are darker and less transition. If I use smaller aperture then I can make it very sharp.
i see plainly the different colour transitions between the 2 lenses as he describes: more saturation in the kit lens. The Tamron rebadge FA28-105mm leans in the 18-55 direction. The SMC-F28-80 is in the FA28-70 camp, but seems more brownish.
When i shoot at night with a tripod, tend to stop all the lenses i use down to f11 or f10. All these lenses here have seemed ok for sharpness stopped down that far, or at any rate with long exposures the K-7 sensor noise behavior and high red-blue saturation levels becomes more prominent than lens optical subtleties from these lenses.
