Originally posted by zuikoholic and paperbag - this is bollocks; we see much wider than the 'normal' view attributed to the 43mm-50mm range, there is just very strong central focus in human vision. the 'soft edges' we decry in a lens doesn't even exist in our own vision!
Is it?
You are aware of the periphery, but to see it, you must focus your fovea on it. This requires you to reorient your eyes and remap attention. An ultrawide image is simply more than we can actually see (it might be the amount we are aware of, but not really processing).
You aren't aware of this because the topographic map in the occipital cortex breaks down - you are able to remember what you saw before, and therefore, detail in the scene is greater then the fovea is actually able to process at any given time.
This accounts for the psychology behind focal length determination. A normal lens captures approximately what you can actively process with your fovea. You can blow that image up quite large, but at the end of the day, you aren't going to be scanning that image much for detail. It's processed much like the section of a scene.
Ultra wide images often encourage you to scan the scene and process little details individually. This is independent of the size at which you print the image. The fact is that your brain applies these strategies to processing the image regardless of how much space they take up on your retina, because you have learned that this particular field of view is that of a whole scene.
Habits habits habits.
Those soft edges do exist, because as soon as you look at them, the fovea makes them sharp. You can't compare human vision to a photograph.... because a photograph still needs to go through human vision.
So, no, your claims are bullocks
