06-30-2011, 01:38 AM   #1
Ben E's Avatar
Tamron 90mm macro...
Hi, I'm pretty new to DSLR photography and I want to buy a macro lens.
I discovered the Tamron 90mm Di Macro, it appears to be an excellent lens.
If I had a decent budget I would just buy it off Adorama right now, but of course my fundings are fairly low so I've been looking at other alternatives.
I've also found the Tamron 90mm Macro which appears to just be an older version. Its also half the price of the "Di" version. One thing though, I think it has an adaptall mount, which I'm not sure what that is really.
So my question is this: Which one would be a better choice, the "Di" version which is more expensive and newer, or the "non-di" version which is older but less expensive. If the adaptall mount is no problem, would the older version of the lens be just as good a choice as the new one? What are the differences besides the mount?
Thanks for your help!
~Ben
(I'm using a Pentax K-r if that affects anything.)
06-30-2011, 02:01 AM   #2
darrenleow's Avatar
QuoteOriginally posted by Ben E Quote
~Ben
If you're just going to use it for macro then MF is perfectly fine, but if you want to use the lens as a fast telephoto such as for portraits, then you might want to get the AF version. Pentax's DFA100WR has rounded aperture blades to give better bokeh, especially for portraiture
06-30-2011, 02:02 AM   #3
darrenleow's Avatar
BTW, I have the Tamron 90 Di version, although it rarely saw use after I got my fast telephoto zooms (DA* 50-135 and then Tamron 70-200)
06-30-2011, 08:01 AM   #4
Ahab's Avatar
I recommend going for the Di version. You should be able to find a used one at a good price. Adaptall mounts can be a pain.
06-30-2011, 08:56 AM   #5
QuoteOriginally posted by darrenleow Quote
I'm not sure that's right... rounded aperture blades would only come into play when stopping down a lens, when they would make the out-of-focus highlights take on slightly rounder shape, but I would think that if you're doing portraiture with a 90mm lens, you'd want subject isolation, so you'd use the lens fully open, i.e. when the aperture blades aren't even in play and the aperture would be a perfect circle regardless of blade shape. I think the rounded aperture blades would come into play more when stopping down the lens in macro situations, when there might be significant foreground/background highlights in the bokeh that could reveal the aperture shape in in a more noticeable way.
06-30-2011, 09:29 AM   #6
I use my Tamron 90mm for portraits and love the bokeh it produces.
06-30-2011, 09:49 AM   #7
Ben E's Avatar
Thanks everyone for your opinions. I am still not sure but I am leaning towards the 'Di' version.
QuoteOriginally posted by rockmaster1964 Quote
Which one do you use? The 'Di' one?
07-01-2011, 10:00 AM   #8
Mine is the DI version.
07-01-2011, 10:48 AM   #9
All Tamron 90/2.8 macro lens has the same optical formula. The DI version (272E) is AF and the Adaptall-2 version (72B) is MF. In order to use 72B, you need to procure an Adaptall-2 PK/A or PK/M mount. PK/A mount will give you all auto functions except AF but is hard to find and expensive ($80~120.00). PK/M mount is cheaper but can only be used in M mode with green button for metering. 72B is priced at 1/2 or less than the 272E but when you add the cost of an Adaptall-2 PK/A mount, the difference becomes a lot closer.
I have the 72B and PK/A adapter because I found MF preferable over AF when it comes to shooting macro. If you are buying the 90/2.8 macro as an all purpose lens, AF will definitely be a plus.
Hope this helps,
07-02-2011, 05:46 AM   #10
Ben E's Avatar
Thanks everybody for your advice. I think I will be saving up for the AF/Di/272E version then
90mm, adaptall, choice, k-mount, lens, macro, mount, pentax lens, slr lens, tamron, tamron 90mm, version
For Sale - Sold: Tamron 90mm macro; Sigma 50mm macro jkglogau Sold Items 14 10-06-2010 12:32 AM
Wanted - Acquired: Tamron 90mm Macro or Sigma 105mm Macro (AUS) Pixley Sold Items 2 09-28-2010 08:32 PM
Pentax 50mm Macro vs Tamron 90mm Macro catastrophe Pentax SLR Lens Discussion 13 09-20-2010 11:24 PM
For Sale - Sold: Vivitar S1 105mm f2.5 1:1 Macro; Tamron SP 90mm f2.8 1:1 Macro; Pentax-F 1.7X thomasxie Sold Items 4 02-02-2010 05:40 AM
For Sale - Sold: Pentax K100d + 18-55mm + Tamron 70-300mm; Tamron 90mm Macro jake123 Sold Items 4 11-09-2009 12:51 PM
All times are GMT -7. The time now is 07:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
