Originally posted by Immunogirl If you try a deck bag, look very carefully at how they seal & test it under pressure before trusting your camera to it. The ones that I've tried have let a small amount of water in where the waterproof zipper ended... That was enough to make me not trust my camera in them.
And... what sort of paddler are you? If you're high angle or a wing paddler, a deck bag is gonna get in the way of your stroke. So's a pelican case for that matter,but at least a pelican protects the camera from impacts
Not really sure what my "style" would be called. I currently have a Black wolf deck bag infront of me, that at times I shove the camera in, but must admit, my stroke is low and sometimes I hit even that. I paddled around Holong Bay in Vietnam a year or two back with my camera and lenses in just a dri-sack in my lap, The kayak didn't even have a skirt, had water, about an inch somethimes in the bottom, camera was dry in the bag, but, I'm glad I can say, I didn't dunk it, dont know if it would have survived that. I did find a bigger, supposidly completly waterproof deck bag, but seeing how I hit the tiny one I currently have, not sure if it will be anygood. Thats why I was thinking the dipac cover. Hmm, might think more aboot that??? I do like those pelicans, its just the bulk I'm unsure about. My Yaks quite old, and has more than its share of "rashes" on it, so not really concerned with what a box rubbing around on it might do, but you are right, you can do some damage with a paddle, I wiped out a fishing reel once, when I had my rod secured under a deck rigging.
2.8 is faster than others, but, if you were in dark small places, it still would be a challange, best thing is to get a hotshoe flash, and run a softbox on it, actually, use of a softbox is what I prefer all the time, gives much better , more natral light, even in fill flash applications. Just set the flash to overexpose +1 to compensate for the loss. Going to weddings in castles in Scotland, now your just showing off (
)....hahaha.
Your lucky to get out in your Yak so often, I'm lucky to get out once a month..
good luck with your next outting, see how that lens goes with a few of the suggestions given... I personally only use Picasa for quick gallery veiwing, I've seen it do some wacky things creating the jpgs as far as colour casts and general quality of the pic, I do all my PP in Photoshop.
Chris
