Originally posted by civiletti How would you "do away with" crop factor? Make it illegal for people to mention it?
Just don't mention it during psychoanalysis.
Quote: I sometimes mount a 165mm lens from the Pentax 6x7 system on the K-5. Crop factor is a useful metric in considering how this functions.
I sometimes mount a 162mm EL on bellows on my K20D. I know that it's FOV will be about halfway between my 140mm EL and M42 180mm lens. Easy-peasy. But I still cheat...
Quote: Focal length, maximum aperture, and image circle are the basic photo lens metrics. That's physics. Crop factor is a handy comparator of image size.
Quite right. Those physical qualities, and the register (somewhat related to image circle) are primary, built-into the lens. Crap.factor is a function of the camera frame size vs other frame sizes, not a property of the lens. FOV is secondary, a function of focal length (lens) AND frame size (camera) and can't be assigned to an interchangeable lens by itself. FOV will even vary amongst dSLRs called APS-C but with slightly different sensor sizes.
The situation is rather like saying at a length of wire of 0.1in diameter is a high-E string. That depends on the instrument neck length, and how much you tighten it. It'll be different on standard guitar, mandolin, banjo, 3/4 guitar, etc. In this metaphor, the neck length is like camera frame size; the string diameter is like lens focal length; the pitch is like FOV. The string/lens qualities don't change. What they're used on, does change; that and how they're used determines the pitch/FOV. Something like that.
