Originally posted by Nowhere Matt The DA 55-300 is perhaps two inches longer than the DA 18-250. I saw no noticeable difference in image quality, though I did not study pixels at high crop percentages in depth.
I have a DA 18-250 and 55-300. The 55-300 wins for better flare resistance, colour & contrast, vignetting, fringing and CA. It's a half stop to stop faster across the range. Both lenses tend to hunt once in a while when they shouldn't. The 18-250 has dismal AF performance in low light, and sometimes can't find anything to focus on where other lenses will. There is a noticeable difference in sharpness in my copies at the long end, in favour of the 55-300mm. The 55-300 also goes a lot further, because the 18-250 is an internal focus lens, meaning it loses range as it focusses below infinity. When zoomed to the 250mm position and 30 feet subject distance, it's down to a 200 mm fov.
Originally posted by Nowhere Matt Both perform as they should with my K-7 but the 18-250 stutters a wee bit with my K-10 running on version 1 firmware. (Yes I am aware of updates)
I still prefer the 18-250 to a 55-300 myself. It's arguable "wide-ishness" easily makes up for the loss on the long end. But they can be a bit pricey.
My 18-250 stutters as well, and sometimes stalls before focus is reached. I have to double tap the shutter to ensure it's finished. The other serious annoyance with this zoom is creep. It
will not stay in position unless it's locked at 18mm or you have your hand on the barrel. Build quality of both lenses is marginal compared to the 18-135mm that I use now (I gave the 18-250 to my wife).
Of course the 55-300mm is not an all-rounder, it is a telephoto lens. I suggest the OP keep his kit lens and add a 55-300 for now. IMO a superzoom is something to get after you have other bases covered.
