Originally posted by twilhelm I came very close to buying the Sigma 30 1.4, but I read a lot of mixed reviews about it and the Sigma 50 1.4 about softness wide open and some have said the colors and contrast aren't up to the Pentax lenses.
I only have two zoom lenses (a dozen primes) and one of them is the Sigma 28-105 2.8 - 4. Although I find the contrast a bit low and colors a little flat (unfair comparison to my 77?) it is a very SHARP lens. And I always get useable images.
People knock the Sigma 30mm because it has soft edges, but that is the same reason people knock the 43mm LTD. I probably would not buy the Sigma 30mm.
I tested two 55mm lenses before buying the Sigma 50mm f/1.4. On an APS-C it give excellent results from edge to edge and f/1.4 is very usable. Bokeh is really good and sharpness at wide apertures is as good as you will find. If you don't need wider apertures (shoot a lot at f/4) then there are better lenses. At f/4 and up both the 43mm and the 55mm are sharper according to the reviewer, but I am not sure the difference is field relevant. I very rarely go past F/4 and shoot a lot at f/2.0 and the sharpness/contrast of the Sigma at F/2 is extremely good.
One thing to note is that the Sigma 50mm is closer to 47mm. There are only a hand full of Sigma lenses that I would consider buying. The 50mm, 85mm, 150mm macro, 17-50 HSM OS, & 120-300 HSM OS. The 50mm, 150mm macro, & 17-50 HSM OS are as good as any "brand name" options on the market..... Other than maybe the Olympus 50mm f/2, 150mm f/2 & 14-35 f/2, but that is a dead system.
