07-13-2011, 01:40 PM - 1 Like   #1
audiobomber's Avatar
18-135 vs 16-45 and 15mm
I wanted to test my 18-135mm, so I tried it vs. a couple of well known performers. There was plenty of light, so I didn't feel a need to use a tripod. I shot a couple of photos with each to ensure I had representative results. I've previously tested the 16-45mm against the 15mm and had the same results. The 16mm is a little sharper, at f4 and at f8. Contrast favours the 15mm, but this is easy to change with a tweak on the contrast knob or a CPL. I didn't add a CPL to the 15mm because it won't take my 49mm B&W, the hood interferes. I don't use the 15mm with a CPL anyway.
I was pleasantly surprised at the 18-135mm in this test, it almost stands up to these wide angle heavy hitters, especially with a CPL. I have previously tested this lens vs my 18-55 II and 18-250mm, wide open at 18, 55 and 135mm and it outresolves both. It is not quite as sharp as my 55-300mm. Clearly it is in the middle of my pack of zooms, not bad for a superzoom. I need to send it in for an AF adjustment, as it needs +10 on my K20D. I will specifically request that they repair, not replace.
https://picasaweb.google.com/bonhommed/Comparo?authkey=Gv1sRgCLOD9LjmoOKTlAE#
Hit the magnifying glass for full resolution images.
07-14-2011, 10:52 AM   #2
Marc Sabatella's Avatar
Thanks for this. I agree regarding the 18-135 - perhaps not quite up to the others (corners not as good as 16-45, center not as good as 15), but close enough to not really matter for most purposes.
18-135mm, contrast, couple, cpl, k-mount, pentax lens, results, slr lens, test, vs
Takumar 135 2.5 vs Super Tak 135 3.5, both bayonet mount, which is better? chongmic Pentax SLR Lens Discussion 7 04-09-2011 11:55 PM
What should be the maximum price for Pentax-A 15mm lens as the DA 15mm is coming up? Mitch34 Pentax SLR Lens Discussion 6 06-24-2008 04:40 PM
All times are GMT -7. The time now is 06:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
