Originally posted by Laurentiu Cristofor Nope, you are missing the point again. The OP and my comments are about issues with adaptability of the M42 lenses specifically to K-mount. The OP would like a similar adaptability solution as he is getting on C/Y mount. I realize it may be tricky for you to detect the focus of the conversation given that several mounts are brought into discussion, but let me try to dispel your confusion - the focus is on the drawbacks of the K-mount that make adaptability of M42 lenses less convenient than on other mounts, like C/Y or Canon EF.
Except canon didn't develop shit for m42 compatibility on their ef mount, they got lucky, hence their are people that have shaved the mirrors on full frame canon bodies to use various lenses. Lastly, the real issue that has been pointed out to you and the OP is that Pentax did not invent the m42 mount. It predated the Asahi Optical 'AP' by nearly 10 years. You also keep talking in circles about changing m42 lenses in the dark which really doesn't matter if the body is a 1949 Contax S or any of the other folks that followed suite when Asahi Optical showed Canon and Nikon what an SLR was supposed to look like and how it was supposed to function. The aperture pin is another issue and some manufactures made an adapter to deal with it because their lenses lacked a-m switches. Takumars of any series did not have this issue. So which is it, the aperture pin or changing m42 in the dark?
Furthermore, canon doesn't make a m42 adapter that I am aware of. Pentax kept the registration the same among the m37, m42 and k-mount bodies. That means the 3rd adapters like the ones used on Canon are problematic for use on K-mount bodies. The 3rd party adapters for canon actually add difference in the registration difference of the Pentax m42/K registration distance because of Canon having the shorter distance. I am looking at a 3rd party adapter, genuine Pentax m42 and genuine Mamiya m42 adapter at present. The Mamiya also had the same registration distance as Pentax because they also went from m42 to their own bayonet mount. Their SX series lacked an a-m switch so their adapter as a spring loaded band in side the threads to press the pin. The 3rd party canon adapter doesn't press the aperture pin, but the flange allows for it to lock and adds distance to adjust the registration.
Lets go back and look at what the OP said:
Originally posted by Jüri I have an old Yashica camera. It has a yashica/contax mount, so I have also aquired an M42 adapter. Using it is as easy as it could get. I just screw it on a M42 lens and get a y/c mount lens with infinity focus and no additonal glass. The adapter even pushes down that pin on automatic aperture lenses.
When I want to use M42 lenses with K-mount, I have to use a tool to insert a ring into the mount. The whole process is very inconvenient and takes time. And if i want to use the aperture on automatic M42 lenses, I need to disassemble the lens and find a way to fix the pin.
My question is why did Pentax make using M42 lenses on K-mount so difficult if it could be so much more convinient for many Pentax users.
Ah yes, the mechanism to push the Pin. Well as has been mention 20 times in this thread, non of the Takumars needed a device to push the aperture pins since they had an a-m switch. There is no glass needed in the genuine Pentax adapter nor any tool needed. M42 lenses have to be screwed onto the body regardless if it is a Zeiss body, Contax body, Mamiya body, Asahi body, Yashica Body, Chinon body, Ricoh body or the Papa Blue Smurf magic m42 body and the same goes with adapters for dSLR bodies. The caveat is to convert the lens to another mount.
