11-20-2007, 01:02 AM   #1
dugrant153's Avatar
M lenses - no aperture control?
Hi folks,
This may be something stupidly simple that I'm missing, but for some reason when I'm shooting with M lenses, the aperture value is unaffected.
In other words, regardless of whether I twist the ring from F1.7 to F22, there is no change in the bokeh and the background doesn't focus or defocus at all. It's more or less constant.
*edit: never mind. I figured it out. M lenses won't work in Av mode. You'll only get wide open aperture all the time. You have to use manual mode, meter wit the AE-L button and then the aperture difference shows up.
11-20-2007, 01:31 AM   #2
blende8's Avatar
To complete this:
For screw mount lenses in the K100D you additionally have to set "FI with S lens used" to "available" in the menu. If it's not set SR cannot be used. (p. 49)
aperture, k-mount, lenses, mode, pentax lens, slr lens
Unable to control aperture heasley Pentax SLR Lens Discussion 16 05-30-2010 01:55 AM
No aperture control photolady95 Pentax SLR Lens Discussion 14 05-16-2010 08:03 PM
135mm 3.5 with no aperture control tortoise Pentax SLR Lens Discussion 3 02-03-2010 05:11 PM
K-x with prime -- no aperture control pentaxpup Pentax DSLR Discussion 9 12-15-2009 07:37 PM
Aperture control with old K mount lenses MattGunn Pentax SLR Lens Discussion 3 07-05-2009 09:04 AM
All times are GMT -7. The time now is 08:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
